Got helm or GM manual? Please help with torque specs
Like to do fluid change for my SS/TC soon.. hopefully someone with a helm manual or
GM manual can help me out with some torque specs... engine oil filter (18 lb-ft?) engine oil drain plug (18 lb-ft?) transaxle filler plug (37 lb-ft?) transaxle drain plug (37 lb-ft?) Also, does the Helm manual show you where to use floor jack to jackup the rear of the car? I got a old GM service manual (2005) that says use the rear suspension beam axle that many said is a real bad idea. Thanks in advance... |
This isn't going to help you a whole lot, but if I recall correctly, the torque specs for the oil filter are right on the cap.
The rest I can't help you with |
i jack up on the axle beam, but on the very ends where the bushing is. i wouldn't want to jack up in the middle of the car using the axle beam as a jack point, seems like it could bend it to me.
Originally Posted by oopsitouchedmyself
(Post 4318178)
from the side not center (of the beam). Now, can anyone confirm those torque specs? :) |
Gm Service Information
Oil Filter Adapter Cover 22 N·m 16 lb ft Oil Pan Drain Plug 25 N·m 18 lb ft Transaxle Drain Plug 50 N·m 37 lb ft Transaxle Level Plug 50 N·m 37 lb ft Transaxle Fill Plug 50 N·m 37 lb ft © 2009 General Motors Corporation. All rights reserved. |
thank you sooo much!!
Originally Posted by rukkee
(Post 4335959)
