Got helm or GM manual? Please help with torque specs
Like to do fluid change for my SS/TC soon.. hopefully someone with a helm manual or
GM manual can help me out with some torque specs...
engine oil filter (18 lb-ft?)
engine oil drain plug (18 lb-ft?)
transaxle filler plug (37 lb-ft?)
transaxle drain plug (37 lb-ft?)
Also, does the Helm manual show you where to use floor jack to jackup the rear of the
car? I got a old GM service manual (2005) that says use the rear suspension beam axle
that many said is a real bad idea.
Thanks in advance...
i jack up on the axle beam, but on the very ends where the bushing is. i wouldn't want to jack up in the middle of the car using the axle beam as a jack point, seems like it could bend it to me.
from the side not center (of the beam).
Now, can anyone confirm those torque specs?
Gm Service Information
Oil Filter Adapter Cover
22 N·m
16 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Transaxle Drain Plug
50 N·m
37 lb ft
Transaxle Level Plug
50 N·m
37 lb ft
Transaxle Fill Plug
50 N·m
37 lb ft
© 2009 General Motors Corporation. All rights reserved.
22 N·m
16 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
50 N·m
37 lb ft
50 N·m
37 lb ft
Transaxle Fill Plug
50 N·m
37 lb ft
thank you sooo much!!
