Got helm or GM manual? Please help with torque specs
Old 09-20-2009, 05:32 AM
JT-KGY's Avatar
Like to do fluid change for my SS/TC soon.. hopefully someone with a helm manual or
GM manual can help me out with some torque specs...
engine oil filter (18 lb-ft?)
engine oil drain plug (18 lb-ft?)
transaxle filler plug (37 lb-ft?)
transaxle drain plug (37 lb-ft?)
Also, does the Helm manual show you where to use floor jack to jackup the rear of the
car? I got a old GM service manual (2005) that says use the rear suspension beam axle
that many said is a real bad idea.
Thanks in advance...
Old 09-20-2009, 10:04 AM
liu
liu's Avatar
This isn't going to help you a whole lot, but if I recall correctly, the torque specs for the oil filter are right on the cap.
The rest I can't help you with
Old 09-21-2009, 05:03 PM
oopsitouchedmyself's Avatar
i jack up on the axle beam, but on the very ends where the bushing is. i wouldn't want to jack up in the middle of the car using the axle beam as a jack point, seems like it could bend it to me.
Old 09-28-2009, 06:35 PM
JT-KGY's Avatar
Yup.. I confirmed that with a GM tech... from the rear of the car, you should only jack up
from the side not center (of the beam).
Now, can anyone confirm those torque specs?
Old 09-28-2009, 08:38 PM
rukkee's Avatar
Gm Service Information
Oil Filter Adapter Cover
22 N·m
16 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
Transaxle Drain Plug
50 N·m
37 lb ft
Transaxle Level Plug
50 N·m
37 lb ft
Transaxle Fill Plug
50 N·m
37 lb ft
© 2009 General Motors Corporation. All rights reserved.
Old 09-28-2009, 09:15 PM
JT-KGY's Avatar
thank you sooo much!!
22 N·m
16 lb ft
Oil Pan Drain Plug
25 N·m
18 lb ft
50 N·m
37 lb ft
50 N·m
37 lb ft
Transaxle Fill Plug
50 N·m
37 lb ft
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
TedSS
26
10-10-2015 04:30 PM
OrangeCoba
10-01-2015 10:00 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: Got helm or GM manual? Please help with torque specs
