hahn turbo catless dp?
i have it on my TC along with the 3" catback. After installing it, i was suprised how quiet it still was, that was until i went WOT and it woke up real nice. the Catless DP doesnt throw anycodes either, which is nice
Did you install the dp yourself? If so, was it difficult?
dude... its a total of 7 bolts... thats it... oh and the 02 sensor. super super easy..... you will need a giant extension for your socket wrench and a flex head to make it easier on the top bolts... all bols are 15mil
I can't see the dp from the top...are there other pieces I need to remove before getting to the top bolts?
That would be correct.... this is my fault i didnt specify... your actually removing nuts not the actual bolt on the top end.... for ever for the bottem end of the DP you will need to grab bolts and nuts... its just sounds bad when i describe it that way lolz
lol...no problem...so when you say that I need a really long extension to reach the nuts, I assume you mean from the bottom...then how do I grab onto the bolt? Do I do this from the top? Sorry for the endless questions...
