help on breaking into the 12s on gms1
Old Mar 23, 2010 | 03:01 PM
wantedSS/TC's Avatar
2.2 60' here on the tune and ran 12's. would be mid 12's with a 2.0 60'
Old Mar 23, 2010 | 03:05 PM
recklessnova's Avatar
sounds good. Dont think I dont know I am leaving a ton of time on the table on the gms1. But I would like to kiss the mid to low 12s on radials with a tune OVER GMS1. Once i get the suspension worked out I think it will be doable.
My track prep sucks also haha its not bad on a big race weekend but you will only get a few passes. test and tune style nights they dont really do anything but sweep it off.
Josh
Old Mar 23, 2010 | 07:37 PM
BYT*SS*TURBO's Avatar
I just don't think you have the MPH for a mid 12 run. You would really need to hook well to make up for the lack in top of 3rd power.
Old Mar 23, 2010 | 09:09 PM
jphugel11's Avatar
Definitely agree about the MPH for mid 12's, but they're high enough for high twelves. First night out with the GMS1 I trapped 108.
Old Mar 23, 2010 | 09:18 PM
Terminator2's Avatar
Originally Posted by BYT*SS*TURBO
Im running Progress springs and make more power and torque, launching the car at 3k I have had 0 issues. The Progress are dropped further then the Pedders too.
I will say that the nose of my car does not lift at all anymore since I put my Pedders on. Hooks a lot better now. The fact that the nose is a lot lower than the rear helps a lot.
Old Mar 23, 2010 | 09:36 PM
Sorry if that confused you guys
I was saying mid to low 12s after a tune on top of the
gms1 reguaress will update when I can with new times
Old Mar 24, 2010 | 12:27 PM
Jaxon's Avatar
You could run a .045 pill on your gms1 for the extra 1ish psi. I know it wont throw a code at all for a fact. Me and my friend put a .035 on his gms1 car and logged it just to see on the stock gms1 tune, didn't really knock even though the afr was really lean to me, although I ran .86 lambda then too...
Old Mar 24, 2010 | 12:50 PM
crypticscifer's Avatar
From personal experience and Term can contest. Runway Enduro's have some sweet traction with extra power going to the wheels.
http://www.wheelfire.com/scontent/Ti...tire1&SKU=1269
Old Mar 24, 2010 | 02:40 PM
jphugel11's Avatar
those tires don't have a very high speed rating. I'd prefer to have a speed rating of at least 150+...I won't be going that fast, but with enough mods you can get close to 120...and for me that's just too close for comfort.
Old Mar 24, 2010 | 02:52 PM
Apologies these are the actual tires, rated for 149+ MPH, drive through a monsoon @ 80 MPH no instance of hydroplaning.
225/40ZR18
http://ssl.delti.com/cgi-bin/rshop.p...&nichtweiter=1
The Conti's will rape them in handling, but not traction.
Old Mar 24, 2010 | 02:55 PM
  #36
thats a link to trailer tires man
Josh
Old Mar 24, 2010 | 03:00 PM
  #37
soundjunky's Avatar
hopefully you guys realize that a tires speed rating:
1) has a safety margin
2) is rated for that speed for a given duration of time
you can exceed the tires ratings - especially if it's for short durations...
... just trying to help.
Old Mar 24, 2010 | 03:06 PM
  #38
Josh
Fixed link
Rules are meant to be broken.....
But My suggestion on this tire isn't anything more than the amount of traction they provide on launching. And 2nd gear drops.
Last edited by crypticscifer; Mar 24, 2010 at 03:06 PM. Reason: Automerged Doublepost
Old Mar 24, 2010 | 06:45 PM
  #39
soundjunky stated the exact reason I dont really worry about speed rating. From what I remember reading most tires are rated at that speed for a 10 min and I am sure failure would be well after that time. Who is going to be able to go over 100 for that long?
WIll check out those tires however If I am spending any money Im putting clicks on it after I break 12s
Josh
Turbo Johnny
Feb 21, 2019 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
maliki778
Oct 1, 2015 07:39 PM
no_ss
Sep 18, 2015 11:03 AM
