Horsepower estimates after upgrades?
Old May 26, 2012 | 06:18 PM
mmack104's Avatar
So right now I currently have Hahn CAI, Hahn DP, Hahn catback w/ Muffler delete, Hahn FMIC, Hahn charge pipe, I am going to get the trifecta tune I belive and I am Curious what numbers I will put up, any guesses?
Old May 26, 2012 | 06:25 PM
emiller's Avatar
Without the tune 260. With the tune depends on the tune.
Old May 26, 2012 | 06:34 PM
chitala383's Avatar
You should see around 300 whp with a trifecta tune. Maybe slightly more.
Old May 26, 2012 | 06:36 PM
MastaShaKe_88's Avatar
you'll praly be around 300ish... it's a nice jump from stock
Old May 26, 2012 | 09:33 PM
SSlobalt's Avatar
You will be at exactly 308 hp and 339 ft lbs of torque. I guarantee this, unless you have a hidden "CSS.NET" sticker somewhere on your car. You will then be around 1000hp.
Old May 27, 2012 | 07:56 PM
mmack104's Avatar
I also have GMS1!
Old May 27, 2012 | 08:13 PM
slapbetcommissioner's Avatar
You would likely net around 280whp and 300-310wtq with the mods. Your torque might actualy be down a bit with the IC and 3" exhaust. And if the Intake is scewing fuel trims you may be getting KR which actually limits your HP. If tuned for pretty much what everyone else said. 300+whp and 330+WTQ and only up from there depending how aggressive. Im assuming you will be running a conservative 22psi?
Old May 27, 2012 | 10:06 PM
mmack104's Avatar
Yeah I do not plan on putting the PSI levels up to the option of 27
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
