how do i know if i have lsd or not
I asked my dealer and he says i do,but how do i check this?I am still in the break-in period,so,is there an easy way to know?Heck,i don't even see my window sticker anywhere,it would be on there right?...
do a burnout, if there is 2 tire marks you have LSD. but in all honesty it should be on the VIN code sheet in the trunk under the carpet.. i forget the code at the moment though.
in a straight line, my non-lsd will cook both tires....around a corner in will destroy the enlated tire.lsd will still spin but hook so much better around turns , but looking for the g85 is the best bet. hope this helps
g85 is the LSD
also, for the new turbos the axles and trans are much stronger, in fact they have the largest clutch that they could fit in there. i think you'll approve of its strength for quite some time, if not...well 5/100,000 FTW
