just a few quick questions
I'm changing my oil tomorrow and also decided I was gonna put some new spark plugs in. I know these questions have probably been covered numerous times but I'm on my phone and the search sucks. I'm going with the ac delco plugs because that seems to be what most are using. Iirc they are supposed to be gapped at .032? I am completely stock atm but in the spring I have a k&n intake, zzp intercooler kit, zzp 3in catted dp that I will be putting on and getting tuned for. Will I have to change anything with the plugs when I get all this done. Should I be going a step colder or anything like that? I don't want to do it twice if I don't have to. Thanks guys
Chris
Chris
Out of the hundreds of plugs I've change I've always just made then hand tight then some and never have had a problem. Just don't tighten them to much, you might strip the threads then have a big problem.
thanks a lot. everything went well. plugs were pregapped to .035 had to adjust one a little. when i tune it im probably not gonna go over 22psi
I'm running stock plugs at stock gap. runs fine. Remember that you're putting plugs into an aluminum head. A small dab of high temp anti seize goes a long way.
