Konis
Old Nov 22, 2012 | 12:19 AM
AyrtonSenna's Avatar
Konis
I've found these Konis "race" which are different from the Konis yellow. Do you guys know of them?
Koni Shock - Race Series CHEVROLET COBALT 2005 - 2009 2817-1500
Old Nov 22, 2012 | 12:31 AM
Wangspeed's Avatar
No springs, no spring mounts, figure out own strut solution, unstreetable.
Old Nov 22, 2012 | 12:37 AM
But they are just struts like the yellow ones, and we just have to match them with springs i.e. eibach or they are supposed to be coils?
Old Nov 22, 2012 | 12:52 AM
ampzor350's Avatar
They are struts. Waste of money unless you want to build your own coil over hardcore autox suspension set up.
Old Nov 22, 2012 | 01:08 AM
Ok so they are not for regular springs, I would have to buy the springs that are made for coilovers i.e. Stance, BC, Ksport or companies like that.
I intend to autox the car, but if they are not as good as other setups, then I'll forget about them. I remember seeing the whole Koni coilover kit for our car on Koni's website, but they are not listed anymore
Old Nov 22, 2012 | 09:41 AM
Wangspeed's Avatar
If you can't weld or source your own sleeves and determine you own linear spring rates, this is not an option.
Old Nov 22, 2012 | 09:46 AM
Got it. All those money and I have to figure out myself what stuff I need to use on those coils..... Then it's just better to get the Koni yellows and match them with good springs. If I ever get rid of my Pedders coils, I'm getting Koni yellows and match them with Sportlines. Much simpler and I still would have a great handling
Old Nov 22, 2012 | 09:58 AM
LS6Rally's Avatar
I have Sportlines for years, I Hated them. i ended up going SSC. but if you are going to AutoX why not Koni yellows and YYZ's from Powell?
Old Nov 22, 2012 | 11:37 AM
My all life, between both here and in my country in Italy, I always had eibach matched with Konis (other that the Dodge Charger on which I had eibach for both struts and springs) and they were always the best setup
Old Nov 22, 2012 | 11:43 AM
Cobra2255's Avatar
Whats the prob with Eibach? I have them and I like em!
Old Nov 22, 2012 | 09:35 PM
Wangspeed's Avatar
Eibachs only make decent linear springs. Their street springs are consistently bad, including on this car. YYZ springs, plus XXX bar is as good of a setup as you are gonna get on a street able Cobalt.
Old Nov 22, 2012 | 09:59 PM
BLue NoTe's Avatar
^ yes. I took a new left turn today wot in second and its was SO neutral I actually thought it might oversteer. Incredible, competitive against anything
Old Nov 23, 2012 | 07:46 AM
LS6Rally's Avatar
my eibachs were 4 years old, and they were a little rusty. other member son here have had the Sportlines fail on them. that was enough for me to pull them off my car.
Pieeater
How to Guide
57
Mar 18, 2017 05:15 PM
Josh@ottp
Aug 31, 2015 01:16 PM
themacguy
Aug 26, 2015 07:18 PM
jasonaudio
34
Apr 4, 2013 04:58 PM
Gravana1
Mar 7, 2007 08:43 PM
