launch control??
launch control??
ok i have my 08 cobalt SS. now for the no lift shift do you have to put it to a setting or can you do it any time. and for launch control do you have to set it..
basically what do you have to press to use launch control and no lift shift..
but no really, what happens if you only pres it once? lol
so before u race someone, u gotta press it twice?
if you press it once it just turns off traction control. pushing it twice at a stop will turn on launch control, your dic should read "competitive mode launch control". then competive mode is turned on and you can use the no lift shift feature. if you are driving and havent started with the launch control just push it twice and see competive mode on the dic and then you can use the no lift shift feature that way
manual dont tell u dick
hittin it once takes traction control off. n u can blow the **** outta ur tires
Last edited by sporttintturbo; Jul 2, 2008 at 08:32 PM. Reason: Automerged Doublepost
is there an icon that indicates that ur in competetive mode?
ok so in conclusion.
press traction control button once = turns off traction control
press traction control twice at a stop = turns on competitive mode and launch control/no lift shift. dic should read "competitive mode/launch control"
press traction control twice while driving = allows you to use no lift shift and dic should read "competitive mode"
no, it will just say "competitive mode" on the dic for a second
HAHAHAHA fail. no. you just dont have to let up on the gas when you shift
If you hold it for 5 sec, it turns off ESC and TCS, lets you go without computer assistance. Not really a good idea, 99% of people will be faster with stability control on. Just use competitive mode. Bob Bondurant said, when he drove the new Z06's, that it was the best ESC program he had ever used when in competitive mode, that there really was no reason to turn it off. It lets you go just about as far as possible while still staying in control. Turning it off would really only be useful if you wanted to drive stupid and not have the computer try and stop you.
