Launching on the strip first time
Old Jul 4, 2014 | 04:05 AM
Chevy_enthusiast23's Avatar
Im fairly new to driving a stick, and just recently bought my 2009 cobalt ss/tc, and i can drive and power shift like nothing, but iv never really had a spot on launch like you would need at the track. Any tips with how to launch effectively, and what type of throttle and clutch feathering needs to be done. I know the car inside and out and all its corks, i just need a little advice seeing as im a newby. Any and all advice concerning running down the strip would be much appreciated!
Old Jul 4, 2014 | 07:18 AM
Powell Race Parts's Avatar
O mi. good luck. ultra low rpm launch and stay out of power hop. Better yet, dont drag race a FWD.
Old Jul 4, 2014 | 10:37 AM
63 Nova SS's Avatar
They are really tricky unless you have slicks. What mods do you have, and are you tuned? Makes a huge difference. If not tuned- feather out of the hole at 2,000 rpms, and only use nls 1-2 and 3-4, don't use it 2-3. If tuned, and 1st gear limited to 15psi boost, do the same, and get out of 1st a little early. Have fun with lighting up the tires when you hit 15psi in 1st, and most of the way through 2nd, and don't nls 3-4th. Don't use launch control unless you either want to spin all day, or kill the car, if the track is sticky ( or break something)
Drag radials help a little, but not alot, will help you to get traction in 2nd a little better. 3rd gear is fun.
Like powell said- fwd sucks at the drag strip.
Old Jul 4, 2014 | 12:02 PM
JapEatr's Avatar
South Central *********
Slicks, cabs and rotated mounts
Old Jul 4, 2014 | 12:15 PM
Previous owner had the gm stage 1. And other than that nothing, but i do have plans for the car so adding hp wont help the case.
Old Jul 4, 2014 | 12:24 PM
But it's fun John. Def launch at 2k at the highest, you'll just spin or get wheel hop
Old Jul 6, 2014 | 02:19 AM
EFoxwell's Avatar
1. Trans mounts.
2. Drag radials/slicks
3. Return to thread and re ask question.
Old Jul 7, 2014 | 11:28 AM
m33pm33p's Avatar
If it's your first time to the strip don't listen to all the drag fanbois and go out and waste your money on slicks.
Launch at 1500-2000rpm so you get a chirp of the tires and maximum forward movement, other than that its just practice practice practice.
Don't expect much, everyone has a hard time their first day on the 1/4.
Also Powell ftw. Cobalts where meant for corners.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
