lnf hahn s20g dyno
Old 08-27-2012, 12:08 PM
  #101
I'm too JDM for you
BLAZIN07SS's Avatar
EVERYONE has at least 91 octane gas. There was absolutely no reason to put 89 octane in it
Old 08-27-2012, 12:12 PM
  #102
Chevycobaltss3's Avatar
Also the turbo flows 600-650cfm which comes out to 500ish chp most which is out of its effiency. So please explain to me how this turbo isn't efficient to make 400s rod? Also my adapter I'm using isn't Hahns.
Old 08-27-2012, 12:13 PM
  #103
What does 89/91 make 1:1? 90 octane. And I'm sorry to tell you, your incorrect because I've driven across te country many times and they don't have 91 everywhere.
Old 08-27-2012, 12:20 PM
  #104
I'm too JDM for you
BLAZIN07SS's Avatar
everywhere has at least 91 in the premium fuel. the only 90 i have ever seen are the stations that get REC 90 that has no ethanol in it
Old 08-27-2012, 12:23 PM
  #105
Projekt's Avatar
Small town, Minnesota, USA doesnt have 91.
I would think any major populated area would however.
Old 08-27-2012, 12:25 PM
  #106
Cobalt_SSTuner's Avatar
91 can be hit and miss in wisconsin at times too.
Old 08-27-2012, 12:30 PM
  #107
Now why would I do the mix. Because not everyone has the 91 or more. And the gas station didn't have 92 only 91 89 and 87 so I went with a more baseline of what numbers can be hit. I even explained myself on why I did it in the thread. My car is actually quicker now then it was then and I'm on 93 octane 14* mid and 17.5 topend (because I'm not getting kr) but also because I keep my 26 til 5k which i have it go to 24lbs then at 6k I raise it to 26 BECAUSE SOME SURGE!
Last edited by Chevycobaltss3; 08-27-2012 at 05:26 PM. Reason: Error and explaination
Old 08-27-2012, 01:24 PM
  #108
AARON-SS-TC's Avatar
Originally Posted by Chevycobaltss3
Now why would I do the mix. Because not everyone has the 91 or more. And the gas station didn't have 91 only 92 89 and 87 so I went with a more baseline of what numbers can be hit. I even explained myself on why I did it in the thread. My car is actually quicker now then it was then and I'm on 93 octane 14* mid and 17.5 topend (because I'm not getting kr) but also because I keep my 26 til 5k which i have it go to 24lbs then at 6k I raise it to 26
THANK YOU, SERIOUSLY...
Do you not think that at 16* mid it would be safe(i know every car is different)? thats what i'm on with the stock turbo and 93 gas.
im taking all of my zzp stuff out, and doing a full hahn setup other than the zzp intercooler/downpipe...
Old 08-27-2012, 01:44 PM
  #109
Nfamous60's Avatar
I 2nd this when i drive to NY i see 90 and 89 in alot of the small towns i have to stop by to refuel.
Old 08-27-2012, 02:40 PM
  #110
I'm too JDM for you
BLAZIN07SS's Avatar
so you went to the gas station that had 87, 89 and 92 and mixed 89 and 91? cool story bro. and why do you have your boost go from 26 to 24 to 26 again? doesn't make sense at all. but hey what do i know right?
Old 08-27-2012, 02:55 PM
  #111
Your right what do you know ecspecially on the s20g setup on lnfs. I dis themix to make 90 octane, this a problem?
Now about why i change it from 26 to 24 to 26. Because surge is horrible no matter the boost in those rpms. I've changed a few things and it's way better but still surges.
Aaron, more timing midrange means more aggressive because when it spools full it'll have that much timing thrown at it.
Old 08-27-2012, 03:12 PM
  #112
what happens in this "surge" part???
meaning it boosts quickly, therefore making the car wanna launch?
Old 08-27-2012, 03:22 PM
  #113
Compressor surge! Not boost spike. Lowering boost there helped it a lot but still has a tad bit. Issue I think is the adapter but also the compressor wheel along with housing.
  #114
I'm too JDM for you
BLAZIN07SS's Avatar
Andrew, more timing midrange means more aggressive because when it spools full it'll have that much timing thrown at it.
that boost change is crap
Old 08-27-2012, 03:40 PM
  #115
So, it really sounds like this turbo needs a conservative tune no matter what...so many flippin variables to figure out when changing the damn turbo, i hate it...
all i know is, i wanna have a stonger power band than the stock turbo, and i wanna be at least 400whp/400wtq and spend less than 2k for everything
Old 08-27-2012, 04:23 PM
  #116
jonathan923's Avatar
5 pages and noone has delivered.
I SAY RETUNED TO 25-26PSI & E47 AS IT SHOULD HAD BEEN SINCE THE BEIGINING. AND SHOW SOME BETTER NUMBERS.
DONE
Old 08-27-2012, 04:32 PM
  #117
lazaro's Avatar
Thats what im gonna do! Homie
Old 08-27-2012, 04:33 PM
  #118
c130aviator's Avatar
You have never been to Colorado or utah, high altitude all you get is 85 87 89. Live and ski there every year.
Old 08-27-2012, 04:34 PM
  #119
Old 08-27-2012, 05:28 PM
  #120
With the higher boost 26lbs no matter what, if i change anything it still does it. With the larger wheels it didnt do it which is why im going to do a 60-1 mitsu td06/td05
Old 08-27-2012, 05:50 PM
  #121
what if you had it at 24psi steady and raise the timing a bit more than the 14*, i wonder if it would still surge and what kinda power it would make on 93???
Old 08-27-2012, 06:10 PM
  #122
ive lowered it to 22 and it did it. Just within that rpm range. the day i bought the car it did it, But ive made it so much better
Old 08-27-2012, 06:12 PM
  #123
Please enlighten mr guru of lnf balts with the 20g! Because lowering it helps a **** ton. those two pounds removed quite a bit of the surging...
Old 08-27-2012, 06:13 PM
  #124
alerosaint's Avatar
New Mexico dont...well at least the part of NM i drove. Like Clovis. The only spot that has 91 is on base, and not everyone have base access
Old 08-27-2012, 06:33 PM
  #125
Frogstofall's Avatar
The best fix for this turbo is to call BNR.
Quick Reply: lnf hahn s20g dyno
