LNF Won't start after replacing VC Gasket
Old Nov 28, 2015 | 04:07 PM
janinexxmariee's Avatar
So we replaced the valve cover gasket yesterday, put everything back together and the car won't start. Won't turn over or anything. Full power, it's not the battery, checked all the fuses and relays. Fuel pump is priming. All the grounds that I know of are bare metal to metal. I did lose the fuel pump relay but replaced it with the rear Defog relay. We jumped the starter through the relay and it started.. But idle was pulsing. And still won't start on its own. Any ideas?
Old Nov 28, 2015 | 09:05 PM
All the coil pack plugs are tight? How about the cam solenoids and position sensors? What about the hpfp pressure sensor, did you plug that back in?
Old Nov 28, 2015 | 09:36 PM
I'd bet another fuse or relay is blown. Did you figure out why you lost the fuel pump relay?
Old Nov 28, 2015 | 10:42 PM
Omiotek's Avatar
Did you just reeplace the gasket or did you powdercoat the valve cover
Old Nov 29, 2015 | 02:58 AM
Sl0wbaltSS's Avatar
Look at everything you removed. Check the battery if that, the connection to all the coil packs, then other basic stuff.
tylerjclance
Dec 13, 2015 06:17 PM
hacadacalopolis
Dec 8, 2015 08:31 PM
dennis69
Nov 29, 2015 08:42 PM
pykie
Nov 27, 2015 07:19 PM
