lnf wot shift problem
Old Aug 7, 2013 | 12:01 AM
drtibalt's Avatar
hey guys , every time I use nls into another gear , the engine makes a weird noise and feels like its sputtering or misfiring, has been doing it for a while now, if I don't use nls ,the engines fine and keeps pulling , I do let my car warm up for a few mins before ripping on it, mods are a minimal , a catless dp and injen charge pipes with no leaks , car does have a rough idle when warm , ive tried new plugs and the same , running on 94 octane , im stumped on this issue , has anyone heard of an issue like this?
Old Aug 7, 2013 | 12:08 AM
Sox-Fan's Avatar
Got Brakes?
yes, everyone that has ever used nls. It's normal. If it bothers you don't nls. Your transmission will thank you for it.
Old Aug 7, 2013 | 12:20 AM
drtibalt's Avatar
it was fine before tho , keeping ur boost in between makes a difference tho no? or is it little?
Old Aug 7, 2013 | 12:40 AM
Don't NLS, problem solved.
Old Aug 7, 2013 | 01:34 AM
kzak104's Avatar
nls should only pop once, shift quickly, but not quicker then you have to
Old Aug 7, 2013 | 03:59 AM
tuned08ss's Avatar
did you turn on competitive mode? i think nls activates when that is on only
Old Aug 7, 2013 | 10:51 AM
Gunney_07's Avatar
no
Old Aug 7, 2013 | 11:01 AM
Sox-Fan's Avatar
Got Brakes?
no x2.
Old Aug 7, 2013 | 11:13 AM
Wert842's Avatar
No x3
Drive like a boss, ESC OFF all the time and find out what all the power is about.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Aug 7, 2013 | 02:17 PM
drtibalt's Avatar
Think I was unclear guys, when shifting to another gear using nls, even shifting fast or letting it pop , or even when I'm already off the clutch in another gear, the engine still sputters/ misfires, if I let off the gas and get back on it its fine, I never drive with traction on , its always on launch control lol
Old Aug 7, 2013 | 02:29 PM
Bluekid99's Avatar
Have a very similar problem even with shifting if I'm wot an shift 6k rpm or so it dallas flat on it's face and it squeaks and then after a second or so it's ok ...no idea
Old Aug 8, 2013 | 01:43 AM
4g63killer's Avatar
I used to get a belt slip sound when I did it. I rarely use it anymore with me zfr and if I do only 3-4
Old Aug 8, 2013 | 05:14 AM
GreenySC2's Avatar
Originally Posted by Wert842
No x3
yes! until it rains, then it stays on...
and why drive with comp mode on? just hold the button and let esc turn off...
Sent from my Samsung Galaxy Note booyahh
Old Aug 8, 2013 | 12:11 PM
SSlobalt's Avatar
Sounds like OP is hitting the rev limit.
Old Aug 10, 2013 | 08:24 AM
tuned08ss's Avatar
No x3
guess im not a boss. i only turn ESC OFF when im racing. everyday driving its on 24/7.
Old Aug 10, 2013 | 10:03 AM
Dart_SI's Avatar
How are your fuel trims? I used to NLS ALL the time till I blew upy stock trans. That didn't happen because of NLS tho. Lol
Old Aug 26, 2013 | 02:04 PM
NickD's Avatar
I think I am having the exact same problem. It's not the rev limiter. You NLS and the engine almost sounds, as silly as this descriptions is, a kid blowing rasberries. If you let off and then get right back on the gas everything appears to be fine. I noticed this after I got my Trifecta tune, but I also did a number of mods at the same time, so I don't know the exact problem.
Old Aug 26, 2013 | 03:23 PM
Soofisahab's Avatar
This
Old Aug 26, 2013 | 03:53 PM
LNFTX's Avatar
I have randomly had this happen a few times on 3-4 nls
Make sure your not too early or too late on the shift
I usually go for the clutch right at 6k or about 200 rpm before redline
One more thing everytime I have tried to nls with the ac on it has fallen flat on its face dunno why
Old Aug 26, 2013 | 05:13 PM
Shortbus's Avatar
If you don't NLS correctly it will do this, you have to be spot on with the shifts.
Old Aug 27, 2013 | 08:30 AM
NickD's Avatar
I'll have to take and post a video of this. I've knocked off quite a lot of NLS shifts without problems and a handful of times I did screw it up and hit the rev limiter or miss the shift, so I am aware of what that sounds like. This is something different and only started happening after I installed some bolt-ons and my tune.
Old Aug 27, 2013 | 09:49 AM
Kyle09TC's Avatar
once i got my tune i havent even tried it yet, my trans and axles makes enough noise now.
Old Aug 27, 2013 | 11:31 AM
tomj77's Avatar
How much u let ur car warm up? The oil needs to be at least around 160 before u should even get on it hard, let alone nls, if ur nlsing before its that warm , that may be ur issue. Make sure ur doing it quick enough. And no u don't have to be in competitive mode to do it. U can be in any mode. Most likely issue is ur car probably isn't warm enough or u lost ur touch and are doing it wrong
Old Aug 27, 2013 | 11:33 AM
NickD's Avatar
The car was definitely warm. I would never conceive of revving my car high before the oil temp is up, unless there's an emergency. I have to make and post a video. I am fairly certain the OP is experiencing the same thing I am.
Old Aug 28, 2013 | 10:11 AM
NickD's Avatar
So much for taking a video of this. Went to NLS 2nd to 3rd and snapped the cable linkage clamp instead...
