A Major Rattle SOLVED!!!
So as many of you know, our cars can make some pretty funny sounds....one of the tradeoffs of having this amount of performance for the price.
So a while back I began to hear a small rattle coming from the rear of my car. Nothing crazy, but it was loud enough to be annoying and was always present. Over the next few weeks it began to get louder and louder. I looked at the rear bumper area numerous times and no panels were loose or parts off center. Finally, I had enough of it so I put the car on rhino ramps and was determined to stay under the car until the problem was solved. I looked at all the bolts, alignments and panels. All were intact....but then I caught something which didnt seem right. One of the lines that goes to the rear rotors seemed a bit close to a wheel. Turns out it was rubbing against the very edge of the inner wheel (as seen in the picture) and over time had started to expose the metal within the rubber hose which had become the cause of the noise. http://farm4.static.flickr.com/3326/...f800e0.jpg?v=0 Apparently, the small bracket which normally holds the hose does not do a good job of holding the line back. I checked the other side and it was the same problem. So what was used to fix this? Zip-ties! http://farm4.static.flickr.com/3652/...a02649.jpg?v=0 It is now firmly pulled into its bracket and the sound has totally gone away. So if you have an odd rattle coming from the rear, check out these lines. They may be the culprit. |
good job will check mine. But someone has to fix the noise that happens when you play as song with some bass it pisses me off so much.
^^^ thought it was just my car lol....its in the window for me:(
Originally Posted by agent007kimball
(Post 3796195)
Originally Posted by Terminator2
(Post 3796254)
I just looked at my car and apparently your car is now missing a little blue clip that holds the line in place. Mine is still holding just fine.
what are those lines?
Originally Posted by koch1ar
(Post 3796360)
actually if i'm not mistaken thats your ebrake cable.
Originally Posted by outtamymind
(Post 3796419)
Either way, I am thrilled it is no longer making noise. |
(Post 3796419)
tru im not rattling but ill check er out
Just wanted to say good job and thank you! Saved some of us the hassle of taking time to find it ourselves.
I'll take a look this weekend, thanks for the heads up!
Now if I could just find the bird chirping in the back seat. :( |
Originally Posted by Iam Broke
(Post 3798888)
Now if I could just find the bird chirping in the back seat. :( Also....I had the plastic tabs that you use to mount a babyseat giving some noise, I now have those in the up position. And the Cable assly that is in the trunk for lowering the rear seats, there is a section in the rear that the cables rubbe on the body of the frame w/ nothing in place to prevent a possible rattle, if you move it around you can hear it, I installed some foam on the cornors to remove that. Might help some of the bass rattle that has been mentioned up top. We should start a THIS RATTLED FOR ME thread and post what we find to fix some of the rattles lol |
Originally Posted by boosted4dr
(Post 3798963)
Do you have sunroof? That was my rattle I could not find, turned out it was the sunroof module which apparently mounted towards the rear of the sunroof I guess. Dealer replaced module/motor and car is rattle free (well for a cobalt on stiff suspension that is, but the annoying rattles are gone)
I'll take a look this weekend, thanks for the heads up! Now if I could just find the bird chirping in the back seat. If one of the nuts have come loose that mount it to the body, it will make that chirping sound as the plastic of the enclosure rubs on the threads of the mounting stud.:cssNET: |
Good lord, I'm scared to start looking for rattles in my car... with poly motor mounts, damn near everything buzzes and rattles!
I now hear a springy "twaaaaaaang!" whenever I close my passenger door. I think it's because I re-adjusted my parking brake so the driver's side is just slightly loose. This causes the passenger side to be very loose, and it probably has a lot of slack.
Originally Posted by Maetrix
(Post 3799138)
If you have the Pioneer system, check the subwoofer enclosure.
If one of the nuts have come loose that mount it to the body, it will make that chirping sound as the plastic of the enclosure rubs on the threads of the mounting stud.:cssNET: It sounds closer than in the trunk though. |
Originally Posted by ssyellow
(Post 3796223)
