Maybe i don"t need a v8
went back up to dealer to look at the black one. 2500 off list is a good price i may just buy it tommorow.
i was a little concern with all noise the motor made but if thats normal. should be a fun car to drive.
whats up with the clutch seems like it releases way late did not feel a hard spring does it get better from a stand still
the dealer also had a red one with lsd/sr and high spoiler
black one was lsd/sun roof
which would you guys go with ? thanks again
the noise is because of the direct injection, and is normal.
and yes, the clutch does catch very high. it's like that in the lsj as well. it takes some getting used to, because the clutch is so short. so many people will burn their clutches, because they ride it a little too much.
Figure about $1500-$2000 for a clutch installed, depending on which one you use and who installs it. You may get it done cheaper, I'm just giving you a ballpark.
No clutch is covered under normal warranty, its a wear item. Usually dealers leave it up to a judgement call under 8,000 miles, anything over that and you are on your own.
Are you serious, $1500-2000? I've never heard of it being that much. I'm not that mechanically inclined, but me and my Brother-in-law installed a new clutch on my Wifes 2000 Celica GTS a couple years ago. Like $250-300 in parts and a days work. I would never pay $1500 for a cluth replacement.
it IS Possible to get a clutch replaced under warranty, if your car is fairly new, but the techs will look for ANY sign of abuse to not replace it. and generally, it will only get replaced if the mileage is low.
Where are you getting your clutches? Thats ridiculous. Last time I checked the clutch for a car ranged from $300-700 and maybe a couple hundred for labor, unless you do it yourself like I always have.
Please go back and re-read my posts, I covered all the points you raised.
