My "Buy a LNF they said..." Problem/Build Thread.
#301
Under normal operation the car appears to be perfectly fine. However, when I go from a 2nd to 3rd shift, sometimes not always, the car spikes the MAF high, drops it to nothing, and cauts boost to 0. If I lift off the throttle and mash it again then it comes back perfectly.
Code is p0103 MAF Voltage High when this happens.
Why? When it is random and the car drives totally fine otherwise with normal MAF readings.
MAF is brand new OEM
MAF is on stock wiring that isn't cut or extended
No leaks IC to TB
This could just be me, but it seems like I don't really hear the BPV when this happens. I have a Forge BPV and normally I can hear it when I let off to shift to 3rd. When the MAF maxes I do not hear it.
Could the boost solenoid on the IM be going bad?
Could the BPV need cleaned and greased?
No leaks IC to TB
#302
No leaks IC to TB
No leaks IC to TB
#303
Does my log show anything in the fuel trims or boost indicating a leak?
I did boost leak test it from the DS intercooler to the TB and there are no leaks coming up.
I just think it is weird that I can build boost fine and hear the BPV in every gear. I can run the car to redline all the way to 4th without a single issue and hear the BPV in every shift. Then, every once and a while, when I do it I hear no BPV noice coming out of second and when I go into third and do 100% throttle the MAF spikes and then fails. Let off the gas, mash it again, and everything is normal.
Could I run the BPV off the manifold itself to see if the solenoid it is on is bad?
#304
#305
#306
Burning the car to the ground will eliminate the water deal.
I wonder why it is happening. I drained all the water out, dried everything out, put it all together and boost leak tested it.
Cold air intake plus living next to the beach maybe?
Moisture rich air?
Its definitely not coolant and I know for a fact there was zero water in there when I put it all back together.
Moisture rich air?
#307
Moisture rich air?
Moisture rich air?
#309
Revision number 5492y5645, **** it, I have lost count.
So I have been having random knock that has appeared to be false all over the mid RPM range. I have also had a lope at idle, and random misfires every so often. So as I have been trouble shooting I got to thinking hmm, I bet this car has the wrong plugs in it. So I grabbed a set of the proper Denso version of the OEM plug and went to install them today. Upon pulling all of the coil packs I find that the plug galleys are FILLED with soot. WTF?!?!?! Come to find out every single plug was not torqued down. They were all threaded in by hand..... Facepalm.
I have officially bought the car that was owned by the worlds stupidest mechanic.
#311
#314
I have a strange feeling the next thread blueLNFftw makes will be something along the lines of:
"Car was mysteriously stolen. Guess I dodged a bullet"
or
"Bad storms rolled through last night. Cobalt caught fire by 1 in a million lightening strike apparently"
or
#319
The plugs inside were correct, which I found to be more unbelievable than them not being tight at all. However, they were at a .040" gap.
I installed the Denso verion of the AC Delco ones (exact same specs) gapped to .031". No one had AC Delcos anywhere close and I didn't want to wait.
#323
It must not be. I have no idea how 25psi didn't push those plugs right through the threads honestly.....
Or how the wheel bearing with only one bolt held together for god knows how many miles.
Or how the wheel bearing with 3 hand tight bolts didnt fall off.
Nor how the rear suspension didnt implode with none of the shock bolts tightened.
Or how 3 bolts holding the trans on was enough.
Or how he felt that attaching sway bar links was optional
Its is the the guy who owned this car had some sort of aversion to a torque wrench or truly believed "finger tight" was plenty....
