My "Buy a LNF they said..." Problem/Build Thread.
Old 12-28-2014, 05:16 AM
  #201
G85 SS's Avatar
Originally Posted by reybalt
Can i buy weisco pistons and use my stock rods? Want to make sure it's ok to do if not I'll just buy stock pistons.
You could reuse the stock rods though I personally wouldn't recommend that. If you have the motor apart its best to replace the rods, rod bearings and pistons all at once. If not, it's a recipe for issues. Others may disagree, but I'd rather err on the side of caution. And I'm a firm believer of do it right the first time.
Think of replacing the clutch without replacing the slave cylinder, master cylinder, throw out bearing, etc. it's essentially the same thing.
Old 12-28-2014, 12:15 PM
  #202
SR Tech's Avatar
Have a L/F high beam problem too. Haven't cared enough to investigate, hopefully just a fuse.
After a day of working on everyone's else's **** I refuse to pop my hood unless terrible things are happening. It took me 2 months with part in hand to get the ambition to replace and program a bad tpms
Old 12-29-2014, 09:49 AM
  #203
blueLNFftw's Avatar
I need to pick a plate out:
RICE COP
TRBO FTW
U RACHET
OEM XTRA
Also, here is my homemade bead rolling tool. I made this out of a set of wire terminal crimpers. These can be found at any home improvement store for about $25. I took a sawz-all (overkill) and cut off the tips. Then used my Dremel to file down the pinching nubs of the jaws. The result is a hand tool that can put a bead on aluminum pipe with minimal effort in a couple minutes. This stopped my lower charge pipe from popping off at 15psi like it would every time without fail.
Car is driving well. The back brake are pissing me off because they lock up when I go and reverse. I am ordering new pads because I am assuming they are hanging up from being extended so far. Also, the issue I had with boost making the brakes soft is gone, but when I reverse they go soft. I am guessing there is air in the back brakes as well.
Clutch is still being broke in so the car has only seen a couple slow pulls to 24psi, but it feels nice. Currently car is throwing a too lean at idle code, but the it is only on a base tune for the blow through MAF. I have to send Term a log and that will get cleared up.
I snagged an OEM boost gauge and will be installing that in the cluster bezel CAD made me for my LSJ. I need to install my Ingalls, rotated mounts, and steering rack spacers. I am also going to swap out my Eibachs for my SSC's and replace the strut mounts. Does anyone know if the LSJ and LNF FE5 strut mounts are the same? I have brand new ones I bought for my LSJ and never installed.
I ditched the sleepy eyes that were on there, installed 12k fogs, and 5k hi/lo headlights. I also installed my Hella Supertones as well. https://www.cobaltss.net/forums/appe...nstall-307952/
Went with Camero SS emblems since they are like $3 a piece where Cobalt ones are over $20 lol
I also installed LED strips into the trunk for the trunk light and it lights up everything lol. I should have only used one. I tried to get a pic but my potato did not do it justice in anyway. I will post a pic with a camera when I installed the courtesy lighting in the foot wells.
I am pretty happy right now, but will be happier once I have the new clutch master to install. Mine is leaking into the car ever so slightly, but is means that my clutch isn't consistent and is engaging really high up. That should be here any day.
Aside from normal maintenance future plans include red colored brakes, new rotors, MSR 045's in gold from my old car, Synapse BOV, and dyno time on the k04. After that I will step it up to the k04 FTW to give the community some real life numbers differences. In the more distant future a s256et is on the list.
Old 12-29-2014, 01:14 PM
  #204
andrewcarr1993's Avatar
It's nice to see that the real SS side skirts fit just as bad as the ones I installed on mine, guess I didn't do it wrong.
On a more serious note though congrats, still my favorite color, and all suspension parts save the knuckle is the same.
Old 12-29-2014, 01:18 PM
  #205
blueLNFftw's Avatar
Yea.
They fit like that on my LSJ and LNF.
Old 12-29-2014, 05:50 PM
  #206
Spawne32's Avatar
Slo car
sml pns
trbo wut
lol trbo
u lost
Old 12-29-2014, 07:55 PM
  #207
Terminator2's Avatar
Yeah with the zzp relocate the maf reads almost zero airflow at idle. I already had +23% added at idle but it must need a bunch more lol.
Old 12-29-2014, 09:11 PM
  #208
blueLNFftw's Avatar
I saw that chillin in the very first table.
I sent you some logs just now.
Nothing too fancy because I am being nice to the new clutch for break in time. Plus I still need that new clutch master
Old 12-29-2014, 09:13 PM
  #209
blueLNFftw's Avatar
Originally Posted by Spawne32
Slo car
sml pns
trbo wut
lol trbo
u lost
Going with: TRBO FTW though I may see if SLOW CAR is available
Old 12-29-2014, 11:42 PM
  #210
Spawne32's Avatar
i made this one for a friend of mine when he wanted custom plates for his ZL1 lmao
Old 12-30-2014, 01:53 AM
  #211
I don't get it
Old 12-30-2014, 12:08 PM
  #212
Spawne32's Avatar
I don't get it
SMALL *****, it was a joke because he drives a camaro, i just threw it in the list for black to see if he noticed.
Old 12-30-2014, 12:23 PM
  #213
blueLNFftw's Avatar
Car is finally legally registered and TRBO FTW plates are on their way.
It is nice to be driving such a quiet and comfy car again.
I will admit, I miss my LSJ. I will take her for one last spin today.
Old 12-30-2014, 12:35 PM
  #214
Spawne32's Avatar
always wanted custom plates, just couldnt justify the pricing in jersey
Old 12-30-2014, 12:51 PM
  #215
G85 SS's Avatar
I thought of getting a custom plate but decided to just go with a specialty plate instead. Got the plate right away and the renewal is the same as my previous plate. All I did was pay a one time additional charge of $25 for the specialty plate.
Old 12-30-2014, 01:34 PM
  #216
blueLNFftw's Avatar
I only paid $15 bucks for it.
  #217
Dumb question what does ftw mean?
Old 12-30-2014, 01:35 PM
  #218
blueLNFftw's Avatar
How long have you been on the internet?!?!?!
FTW = For The Win
Old 12-30-2014, 02:39 PM
  #219
TotalChaos's Avatar
FTW = For The Win
I always forget it means "For The Win"
I always think it means "F*** The World"
Nice build by the way! I just picked up a '10 LNF.
Pretty fun so far. Seeing your build keeps me inspired!
Old 12-30-2014, 02:41 PM
  #220
blueLNFftw's Avatar
i was originally looking for a 2010, but for some reason people selling the 2010 thought it was worth 2-3k more than the 2009 lol.
Old 12-30-2014, 02:45 PM
  #221
TotalChaos's Avatar
The one I bought was the only one in greater metro ATl at the time. Okay deal but thankfully only has 53k on the ODO
Old 12-30-2014, 02:48 PM
  #222
blueLNFftw's Avatar
Mine had 57k on it when I bought it.
Nice. There was on in metro ATL (red loaded 2010) that had 3500 miles on it! The guy wanted 18k for it though!
Old 12-30-2014, 02:56 PM
  #223
TotalChaos's Avatar
I have not seen any around. That's a little much for this car already 4 years old regardless of mileage. I think the upgrade over the LSJ was a good move but obviously dealing with all this non-sense was unacceptable.
Old 12-30-2014, 03:01 PM
  #224
blueLNFftw's Avatar
I kind of miss my LSJ lol. This car is way more comfortable and definitely faster, but the LSJ had a better linear powerband with better trans gearing.
Regardless, I do love the car and I will like it more when I get it where I want.
Next steps are:
Clutch master
Replace reverse lights with fresh ones
detail the crap out of the car
find a black radio
Red Calipers
install gold MSR 045's I have
At that point I will be super happy with how it looks.
Old 12-30-2014, 03:51 PM
  #225
user 72239's Avatar
I want LOL AWD or OMGAWD for my STi.
Quick Reply: My "Buy a LNF they said..." Problem/Build Thread.
