need help getting the cobalt out of the mud
Old Dec 5, 2009 | 11:40 AM
recklessnova's Avatar
Ok so my driveway is dirt no gravel or anything. My garage is in the back of the house and last night it was raining, sometimes its a little bit of a pain to get into the garage but I got stuck last night about 4 feet in front of the garage. I feel like a jack ass This is the first time I have ever been stuck in anything and not been able to get it out. My problem is I dont know where its ok to attatch a tow strap to the back of the car I thought the rear axle are but didnt want bend it or something. and dont want to jack the crap out of my bumper.
any ideas?
can not drive the car foward or back tried digging it out with no luck
Josh
by the way you can all point and laugh as much as you want I deserve it
Josh
Last edited by recklessnova; Dec 5, 2009 at 11:40 AM. Reason: Automerged Doublepost
scottyguy401's Avatar
Do you have some boards of wood to lay a path for in the front of the car?
Old Dec 5, 2009 | 11:43 AM
yea I was already going to try that one but last time I tried that it didnt help much and shot one into the garage putting a dent in the wall... It was pretty funny actually
josh
Old Dec 5, 2009 | 11:44 AM
Force's Avatar
Lay down some plywood in front or behind the front wheels for traction and get someone to gently push the car onto them.
If it's not stuck down to its axles or something, there's also the tried and true method. Get someone brave to just push the front of the car while you floor it backwards. This has gotten our vehicles out of shallow mud a few times... You might owe your friend a few beers though, since he'll be DRENCHED.
Old Dec 5, 2009 | 11:56 AM
Terminator2's Avatar
any ideas?
Josh
Josh
Carpet or floor mats crammed under the front tires will give more traction than just boards alone. You could lay down boards with a little rubber or carpet nailed to them. You should get someone to rock the car as you try to drive it out.
Old Dec 5, 2009 | 12:24 PM
Iam Broke's Avatar
A long time ago I buried an old '64 Dodge in a field. Tried boards, mats ect. Thank God for farmers and tractors and chains.
I would think if you used two tow straps on the axle close to the wheels you'd be ok, but I'm no expert.
Good luck, no laughing from here.
Old Dec 5, 2009 | 12:36 PM
D4u2s0t's Avatar
these are what I would suggest. If you have to tow it out, I would attach the tow hook to the frame somewhere, not the torsion beam. It MAY be ok to pull from the beam, but if you're under there already it's just as easy to attach to the frame, and much less risky. The torsion beam is strong, i've jumped up and down on it no problem, but that's up and down, the way it's designed to move. I'm not sure how it would hold up being pulled backwards with the weight of the car. Personally, I wouldn't risk it. The torsion beam is expensive.
Old Dec 5, 2009 | 01:12 PM
I agree, I think the amount pressure exerted on the torsion beam would likely bend it if you tried to pull it from there.
Old Dec 5, 2009 | 01:14 PM
well got her out sort of. what I did was use one of my floor jacks and jack up the back end once that was in the air I had enough room on the front to put my other floor jack under where I have been lifting it by right behind the front tire. jacked up and laid down one of my trailer ramps under the front pass tire its about 6 feet ling and I laid it down upside down so the open side of the angel iron was facing up. It got me into the garage anyway I was more worried about messing up under the car like the intercooler as the mud was about a inch or so below the lip haha.
Thanks guys I looked up under it and its still clean around the engine area so thats good.
hopefuly no mud in the tires (my cousin vinny)
Josh
Old Dec 5, 2009 | 01:15 PM
Black SS/SC 06's Avatar
Josh
I am laughing
Good luck
Old Dec 5, 2009 | 01:16 PM
Judder's Avatar
Where is the pics haha.
slowswap's Avatar
Lay a bunch of kitty litter under the front tires. Attach a strap to the rear torsion beam. Don't pull it out though. Use another car to aid in the pulling. You should be in your car letting your car do must of the work.
You will not hurt that rear torsion beam unless your hanking the car of pulling the car well not making any forward progress.
Old Dec 5, 2009 | 01:31 PM
JohnnySasakiMGS's Avatar
You might cause the clutch position sensor to get an error if you slip the clutch while rocking the car. Just be prepared to lose your cruise control and to get the code erased at the dealer.
Old Dec 5, 2009 | 01:38 PM
Iam Broke's Avatar
Glad you got it out of the mud! Time to order a load of Grade 8 stone for a base.
Old Dec 5, 2009 | 02:24 PM
No kidding right
I looked into laying a rock drive way but its going to run me over a g for rock and that does not include getting the top soil scraped off so it all dosent all just suck into the ground major downer. will have to bring in at least a truck load to spread on the driving lines into the garage but hell thats 400 for a tandem
didnt get any codes and I have a dash hawk so I could reset it anyway. Whole reason to pull it into the garage was so i could install my freshly painted headlights and not get wet.
Josh
Old Dec 5, 2009 | 03:18 PM
06G85's Avatar
Pics or ban
Old Dec 5, 2009 | 03:36 PM
scotch89's Avatar
Pics !!!
Old Dec 5, 2009 | 04:36 PM
all so I could put these in
what a pain in the butt I really need to lay down something Ive been here for a year and it only lately like the last few weeks got this bad
Old Dec 5, 2009 | 05:16 PM
Force's Avatar
That looks kind of bad ass.
Old Dec 5, 2009 | 05:42 PM
I love the military stenciling on the orange marker.
Old Dec 5, 2009 | 05:50 PM
631motersports's Avatar
id give it a wash if ur still trying to sell this haha
Old Dec 5, 2009 | 06:00 PM
Thanks for the pics lol
Old Dec 5, 2009 | 06:20 PM
Cobalt_Daddy's Avatar
got my TC hung up on rocks once when i went off the edge of a gravel driveway backing up in the dark... bent the heat shielding around the exhaust... towed it out with driving and a 4 wheeler... don't remember what i hooked the strap to but it was a beam somewhere up front. good luck!
Old Dec 5, 2009 | 07:01 PM
crypticscifer's Avatar
too bad they didnt make the tow hooks yet...
Old Dec 5, 2009 | 08:42 PM
I decided to keep it a while back Thats when i started playing with it for now its got a gms1 zzp catless dp aem intake and a muffler delete I did go to town and washed it good underneeth and on top haha I thought the headlights turned out good I will take more pictures tomorrow and post em up in the appearance forum
Josh
