New record!! 18 degrees outside and 7 psi
At this rate I might be boostless at -5!! And yes...I need a tune :)
I was driving yesterday and was trying to watch my boost guage when shifting, seems I am still around 15 and my temp was way below freezing yesterday with a wind chill of like COLD lol but your still making 260/260 so its all good right? lol
Originally Posted by WaRRioR-StaTuS
(Post 3237534)
well he said he does not have a tune so I believe the learn down feature will still be in effect so then yeah, if I understand correctly. Thats why I put a question mark after because i was kinda asking if that is correct.
Yea the computer is programmed to run less or more boost to make that 260 hp 260 tq no matter what.
thats what I thought, thanks for clearing it up
lol i was running approx 8psi the other night, it's in KPa and I was busy keepin the car on the icy roads but i glanced up once to look at it was about 60-80Kpa at best, maybe lower lol
Talk about a buzzkill
I only go to about 60 kpa which is 8 PSI and it was -19 this morning.
Originally Posted by vB00STw
(Post 3237550)
So you're saying that because of the temperature, he is running less boost but the same amount of HP right?
obviously..... ohh and nice GLI i have one to but im selling it to get an ss/tc :thumb:. if only GM didnt have the learn down function youd be boosting at 15 and be so much faster. I guess that kinda is a good thing though considering that there would be more "snow took another victim" threads. |
id be taking it easy on your car when its frigid... I try to stay out of boost entirely....i mangled a syncro on a brisk shift in my WRX with an ambient temp of -1 degrees. make extra careful shifts, and watch out for axle hop, everything is more brittle in the cold.
I saw 12 psi last week. At first I thought I read it wrong but it was by far the coldest temps of the winter so far. It was 1F outside.
Not to one up someone but it was -10 last week and I saw only 9 psi and yesterday as I was leaving my second job I floored it and bearly touched 5 psi. I was thinking the same thing. "Am I really getting 260hp off of 5 psi??"
Originally Posted by El_diablos_SS/TC
(Post 3254266)
Cold air is denser so more air fits in the same volume. Its the ideal gas law. Pi Vi / Ti = Pf Vf / Tf Pi = Initial absolute pressure (kPa), 230kPa ~ 33 psi Vi = Initial volume (L), this doesn't change and is fixed ignore it Ti = Initial temperature (K), 300K ~ 80F Pf = Final absolute pressure (kPa) Vf = Final volume, same as Vi Tf = Final temperature (K), 250K ~ -10F Pf = (Pi x Tf) / Ti = (230 x 250) / 300 ~ 192 kPa ~ 27.8 psia - 14.7 psi ~ 13.1 psig I estimated and rounded the numbers but it should be close. Also you don't get full boost until the engine is warmed up. |
Originally Posted by SSBalt
(Post 3237515)
Originally Posted by Terminator2
(Post 3256104)
That says a lot for how efficient the LNF is,:twothumbs but just imagine how much power you will make at that temperature when you are tuned at 22 psi.
I dont see why ur having trouble with you boost at colder temps... Its been -40 degree celcius and i still hit 110kpa right around that 15psi
