No 6speed for Cobalt SS??
I have a '00 Camaro Z28 M6 and was considering to buy a Turbo Cobalt SS. I was disappointed to see it will only come with a 5speed and no optional 6speed with a deep overdrive for better gas mileage. Any news of GM offering a 6 speed in the future?
I like the 0.50:1 6th gear on my Z28 since it will get ~29mpg on the highway. With the smaller/lighter Cobalt with direct injection, I was hoping for better than 30mpg on the highway.
You dont need overdrive or more gears with a 4cyl
gotta remember that its a 4 cylender, it doesnt make power low down and with a deep overdrive you will have your foot a lot farther into it, so you wouldnt get a lot better mialage.
my ss/sc with all my mods i can get 35mpg on the freeway. the ss turbo should be a bit better with the different final drive (3.83 vs 4.05) and direct injection.
I agree 100%
we complain about fuel mileage and they make our engines SCREAM down the highway at 3krpms.. they only need to be ~1500-2000rpm's. All the extra friction power is wasted just to spin the engine that fast.
Thanks for all the replies! I did realize that the Cobalt is a Turbo 4 cyl.
That being said, at 80mph, the Cobalt's 2.0 is turning at 2900rpm. With torque peak at 2000rpm, It would be nice to have a taller overdrive gear. I am happy to see some getting as high as 35mpg with the SS/SC, but if the gearing was taller, that number would be even higher. Right now, the 0.70:1 5th gear is optimized for top speed.
While I'm nitpicking about the transmission, I wish the 1st gear was a bit taller as well and gap between 1st (3.38) and 2nd (1.78) was smaller.
FWIW , the 08 Turbo cars lost some ring gear . SC's were a 4.05 , the new one is 3.84 .
I calculated mine with good ol math ( not the DIC reading ) , and got 36 mpg on a trip to Ohio last month buzzing 3K rpms I average about 24-25 in town . I dont see how you could do better than that with the TC .
the ss/sc is cranking 2900rpm at 80mph, however with the lightly deeper final drive of the ss/tc, it will be a tad lower at 2800 at 80mph. not a big difference, but some.
as i said earlier, a v8 you want under 2000rpm for cruising, however a 4 cylinder chugs along at that rpm. you will need your foot farther into it to maintain speed and you can end up with worse mialage. gm isnt stupid when designing the overdrive ratios, they do testing to find out what will optimize fuel economy, and thats what they came up with. remember, the new turbo cobalt has the best fuel economy of any performance 4 cylender on the market, beating the mazda speed 3, srt4, and even the civic si
....The engineering team for the Cobalt has extensively tested the F40 6-speed and could find no justifyable benefit in performance or economy over the F35 . It was gone over when the SS/SC was in development and again with the TC .
Its not the best of the best , I think ratio's need work in this car ....but its the best of what they have avail. to use in the Cobalt SS .
It's very very close. I've never been off by more than 1 mpg. Mine tends to be slightly lower than actual mileage. For a full tank of pure highway it would read 36.6 mpg, when true math would give 37.3.
My LT only gets like 37 cruising the speed limit...I can average 35 on a trip with some stops if i accelerate like a granny. I do have alot of weight in the trunk though. probably about 200+ lbs. Full set of tools, Jackstands, and another toolbox full of car detailing/washing stuff. (I have an apartment so I dont have my own garage)
