Oil seepage around Main Vacuum line fitting
Old Jun 24, 2013 | 10:31 PM
Gixxercobaltdriver's Avatar
Hey, I am noticing that there is a wet mark around the Main Vacuum line fitting on my intake. Its the fitting on the intake all the way to the right... Any idea why it might be doing that? I do not think it should be doing that, as there shouldnt be any kind of oil getting into the intake..
anyone else's LNF do this?
Old Jun 25, 2013 | 12:03 AM
kzak104's Avatar
oil/blowby from the pcv get vented into the intake, not sure why the line is leaking, that is if your talking about the braided steel line on the intake. if not then ignore me
Old Jun 25, 2013 | 07:47 AM
RaymondT's Avatar
Mine has that too, dont know why but im not too worried.. You cant sweat the small stuff with these cars.. And its alot less oil than u think.. Oil spreads a lot. And have you ever taken a look at an old pcv valve.. Itll be covered in carbonand oil
Old Jun 25, 2013 | 09:16 AM
tomj77's Avatar
Never seen that. I'd get a catch can, that will gunk up ur valves petty quick if ur seeing it coming out there already
That or u spilled a few drops when u did oil change
Old Jun 25, 2013 | 10:14 PM
RaymondT's Avatar
mine developed it from sitting over the winter
Old Jun 26, 2013 | 11:11 PM
My car sat for a year when I deployed over seas... Its not that much, definitely did not spill in that area during an oil change, that just makes me think that there is a lot of oil getting into the intake.. I wonder if that is because of a bad PCV valve.. i will have to take a look.
Old Jul 12, 2013 | 10:47 PM
10CSSTC's Avatar
What did you end up doing to fix it? Mine has the same issue.
Old Jul 14, 2013 | 02:01 PM
SSlobalt's Avatar
If OP is talking about the brake-booster line, I have it, too.
Old Jul 16, 2013 | 11:41 PM
Alleynejl's Avatar
mine has the same issue hasn't really affected the car that I've noticed tho
Old Jul 17, 2013 | 12:17 PM
10CSSTC's Avatar
So how do we go about replacing this? I have a feeling that's why there's trace oil residue near that area
Old Jul 18, 2013 | 08:04 AM
SSlobalt's Avatar
I haven't messed with it. It's just oil reside in the intake. It will just keep coming back unless you buy one of those Powell oil catch-cans.
Old Jul 21, 2013 | 08:23 PM
10CSSTC's Avatar
I cut the tip off and reclamped the hose. A new one is part #20917036. $100 from rock auto
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Oct 1, 2015 08:17 PM
