Other BPV/BOV options
Ok I have had a stock BPV, Forge BPV, and a HKS BOV installed. I am a fan of the HKS BOV. When I got the BOV installed we removed the solenoid that routes all the vacuum lines around and the vacuum tank as well as blocked off the nipple on the cold side charge piping. So after all that and BOV installed I had turbo surge. So I then I went out and bought the forge BPV. Personally I don't like it, way to quiet, even the stock was louder. But I want the BOV back on so...
First I called Vince at trifecta and he told me to try installing the vacuum tank and all other parts back on and try the BOV again, he said it might work. (haven't got to doing that yet) but any other suggestions on how to run a BOV without surge. Tell me your setups cause I know several of you run HKS SSQV 3's |
Subd
forge bpv sounds great if you ask me. and way louder than stock. and its stress free unlike a bov haha
i have the tredstone block off plate, tial bov with the vac line straight to the intake manifold, i just left the solenoid alone, runs the same as she always did
Ok obviously my forge isint installed right or something. Cause at full boost and letting off there is no sound. Then at low boost just a quiet psssshh.
Originally Posted by TheBoss8688
(Post 6122659)
Not sure. I'll pull it out and check that
Pics of your hookup!!!
I bet that it is routed wrong. I have Forge BPV and its hella louder than stock. |
I had the same issue with my HKS SQVIII bov, after doing the following I get zero surge and no audible flutter. Vince at Trifecta saw compressor surge with the stock set up and after doing this and data logging there was no surge.
https://www.cobaltss.net/forums/2-0l...lutter-259599/ Also I have the stock bpv blocked off with a treadstone plate. |
