P2178??
P2178??
This is my 10th time my car has turned up this code. Me and my mechanic are at a stand still and not sure what to do. I am sick of my car already -_- We've replaced the MAF sensor, O2 sensor, and all air filters and I even started using 94 Fuel because GM said that the cobalts generate a "fake" code which is the P2178 and that means the car is running too rich. Does anyone have any history with this bastard and know the answer?
already shaved that bolt awhile ago, took it to dealership... charged me 70$ to tell me I have a problem and that code... ******* scum bags... they said they also don't know how to fix it... great... looks like ill be like others who switch to a sti
An STi won't give you any less trouble than any other turbo car. To own a turbo car, you have to be able to do some basic maintenance.
Although, if I could afford an STi, that means I could afford a 3-series beemer, which I would then buy and wave goodbye to the 'balt.
bunch of friends own sti's... flawless so far *knocks on wood* and ive called they were not very helpful either... im just ticked that they charged me and did nothing except scan the code and tell me what the code was which im already aware i just want the damn thing fixed
mines throwing the same code "SYstem too rich at idle bank 1"? im going through getting them to fix this, they replaced engine and still throwing code, i think i may have leak in intake side considering i can hear a vacuum sound when i drive normally without boost, my AFRs have also been rediculous lately and very inconsistent, not normal type of inconsistent. around 3k rpm my car kind of bucks and jerks, let me know if you get anything fixed man, ill do the same for you.
Goodluck bro, im starting to feel the same about my cobalt, i cant wait to trade the thing in, honestly dont know if ill ever go to Chevy again :/
So i just got a call back from dealership, and they are almost 100% sure they found the culprit, they are replacing my intercooler, and i should be getting it back tomorrow, i also had bad AFR inconsistency along with this code, so if your also having this problem that could be where to check, keep an eye on your gas guage... i filled up on a wednesday amd by friday my car had half a tank dropping it off at the dealership, so just keep an eye out for anything getting fishy, or worse if youve already noticed it.... If you drive around and hear almost a vacuum suction this could be a good place to start, i noticed this and informed the technician working on my car, they contacted the technical line for GH, took a couple days and thats what they have come to
If youve made it this far in my lifes story with my car, ill keep you posted on performance when i get my car back from dealership
