PI for RPD
Old May 13, 2010 | 04:47 PM
rukkee's Avatar
PI for RPD
Service Information
Home Number Search New Bulletins Bulletin Search Feedback Help
Document ID: 2470794
#PIC5350: Intermittent IPC Gauges WOW Multiple warning Lights On May Or May Not Have Codes P0575 U0140 U0121 U0073 P0703 Set - keywords ABS boost cluster communication DTC gage gauge inop inoperative IP light - (May 12, 2010)
Subject: Intermittent IPC Gauges WOW, Multiple Warning Lights On, May Or May Not Have Codes P0575 U0140 U0121 U0073 P0703 Set
Models: 2009 - 2010 Chevrolet Cobalt W/UAF Configurable DIC
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that the IPC gauges WOW and/or multiple warning lights are illuminated. Upon inspection technician may find DTC's P0575 U0140 U0121 U0073 P0703 stored.
This may be caused by a pinched harness between the I/P carrier and body mount.
Recommendation/Instructions:
Remove IPC & instrument panel cover to gain access to the configurable DIC harness. Inspect harness 14 inches from display at the IP carrier mount on left side of dash for pinched wiring - See attached photos.
Object Number: 2466174 Size: SH
Click here for detailed picture of above image.
Object Number: 2466175 Size: SH
See SI Document ID: 1378906 for approved GMLAN wiring repairs.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2010 General Motors. All rights reserved.
Old May 13, 2010 | 04:53 PM
ctn2mb's Avatar
Originally Posted by rukkee
Service Information
Condition/Concern:
Interesting, I've never had this problem
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
SiloGM
Sep 7, 2015 11:04 PM
