Piston3's LDK Swap
Old 04-12-2014, 09:11 AM
  #176
crashher0's Avatar
Originally Posted by Piston3
And then the testosterone kicked in. Had it at 3500 in 2nd and just mashed it. AFR dropped into 11s and quickly locked at 12.7 as it rocketed forward, followed by the loudest "chuff" from the bpv I have heard so far as I let off. I passed them both under heavy braking. They wanted nothing more to do with me.
I had been pushing it a little harder each day this week and am at 500 miles as of tonight. First oil change tomorrow and switching to Mobil 1. Running stronger every time I drive it.
I have a car boner right now... isn't this considered ****?
Old 04-12-2014, 09:37 AM
  #177
TCBalt09's Avatar
Ok so it happened. It was an accident sort of. This kid in a fake Evo with a retarded wing and muffler was being stupid to my right, then this other idiot in an obviously modded Kia Forte on my left starts trying to screw with me. They were both ahead of me because I wasn't biting. Im more thinking are these guys serious? And then the testosterone kicked in. Had it at 3500 in 2nd and just mashed it. AFR dropped into 11s and quickly locked at 12.7 as it rocketed forward, followed by the loudest "chuff" from the bpv I have heard so far as I let off. I passed them both under heavy braking. They wanted nothing more to do with me.
Welcome Back. Thank the car gods that you didn't send a rod through the block or something
Old 04-12-2014, 07:19 PM
  #178
Piston3's Avatar
No danger to manifold warnings here.
Had to buy the 32mm oil filter pod socket. There is just no room to get to that thing any other way. Took exactly 6 quarts. Not a drop of any fluids in sight, no rubbing, and I think I blew all the crap out of the muffler because I dont smell burnt motor anymore.
What kind of gains do you think I'll see from canned tune to dyno tune? On canned 91 right now but may go 93 for the dyno.
Old 04-13-2014, 06:28 PM
  #179
crashher0's Avatar
With your mods in your sig and the LDK on a canned tune at least 300-320 easy... edited tune you could pump out some serious numbers though!
Old 04-13-2014, 07:15 PM
  #180
taintedred07's Avatar
Any tune should be better than a canned tune.
Old 04-14-2014, 08:32 AM
  #181
Omiotek's Avatar
Every car is different canned tunes can always be improved on
Old 04-16-2014, 11:23 AM
  #182
Piston3's Avatar
Almost 600 miles now and still getting better every drive. Actually had some torque steer last night. I have been short shifting it around 5k and no heavy throttle unless 3500. It's really weird to be able to feel an engine break in. Also clutch engagement is higher now where it should be as expected.
Old 04-17-2014, 08:10 PM
  #183
Piston3's Avatar
Anyone with the ZZP tune see a 26.4 psi spike? That scared the **** outta me. I'm done til it's been tuned properly. Thank God I didn't burst into flames or get hit by lightning.
Old 04-17-2014, 08:19 PM
  #184
Cobe's Avatar
I left zzp with a 21 psi canned tuned with gms1 sensors ..... pulled out.. nailed second gear.. spiked 27 lol. Shoulda turned around.. Went home. Beat all my friends... Blew turbo month later lol
Old 04-17-2014, 08:30 PM
  #185
Take a deep breath and ignore Cobe. I forget if you have the mechanical faced gauge or the RPD, the mechanical faced gauge is meh on accuracy. I watched mine spike to 27 one night with the WR-1, my turbo is still fine (over 7k miles since the 27psi spike)
Old 04-18-2014, 12:10 AM
  #186
Piston3's Avatar
It's a 2010 so it's RPD. Perhaps that's just a limitation of an internally gated system and a very fast spooling turbo. It can't keep up. I need an interceptor so I can keep an eye on multiple things. I have seen 2 degrees knock retard at full boost but usually hangs at 1 or 0. No reason to take chances this close to getting a tune. I'll take it easy.
Old 04-20-2014, 10:22 PM
  #187
Piston3's Avatar
Ok so I have over 1,000 miles on the new engine now and it's getting closer to tune time. I am debating on going with E85 as it's about the same availability as 93 and if I choose to have to hunt down fuel it may as well be worth it.
However, I don't want to be paranoid and I don't want to have to test fuel every time I fill up. Is it possible to tune for this scenario? Do you guys running E even test yours anyway? Is there such a thing as a conservative E85 tune or am I better off keeping this simple and sticking with 91? Remember I only drive this car when it's sunny.
If I have missed a thread about fuels and tunes please share a link!
Old 04-20-2014, 10:25 PM
  #188
Someone installed a ethanol sensor inline to determine what grade blend they got. I'd just go for a 91/93 tune.
Old 04-21-2014, 12:09 AM
  #189
Piston3's Avatar
The whole ethanol thing sounds like a huge pain in the ass the more I read about it. I'm not interested in having a paperweight for 5 months again.
Old 04-21-2014, 04:42 PM
  #190
Lol @ ethanol sensors
Old 04-21-2014, 05:42 PM
  #191
cfsnipers's Avatar
Get a 91 tune and run 93. It will last forever. Ive got 310whp and 335wtq on 91. That's plenty for now. Kevss said its a very mild tune. 23psi.
Old 04-21-2014, 06:24 PM
  #192
http://www.zeitronix.com/Products/ECA/ECA.shtml
Old 04-21-2014, 07:19 PM
  #193
How is running E a PITA? Put it in the tank and go. Test it if you like.
Old 04-21-2014, 08:17 PM
  #194
Piston3's Avatar
You just fill up without worrying about it? What if it's an unfamiliar station out of town and it's a couple months old? That's my main concern as I travel to Des Moines and Chicago from Davenport fairly regularly and will be taking the Cobalt if the weather is right.
Old 04-21-2014, 08:20 PM
  #195
Piston3's Avatar
What mods do you have? That might just be fine with me actually.
  #196
Depends on availability of E around and if you take long road trips, I wouldn't want to have to swap fuels just for a long trip or hop
E station to E station
Old 04-21-2014, 09:01 PM
  #197
cfsnipers's Avatar
ZZP small intercooler, Hahn hot and cold side turbo piping, K&N Typoon SRI, Hahn Catless DP, TWM SS, HP Dual Tuned at 23psi and 18psi.
Never ever seen a hint of knock retard. Clutch is starting to slip tho. KY stage 3 coming soon. 4.05 gears too.
Old 04-21-2014, 09:14 PM
  #198
You can buy a tester on eBay and test it at the pump. That's what I'm going to do once tuned on E47. If I plan on going out of town I'll bring a couple 5 gallon containers of it with me just in case.
Old 04-22-2014, 02:57 PM
  #199
Piston3's Avatar
I've decided to stick with 91 and a progressive boost ramp. Whatever the LDK makes is where it'll stay. It will still be loads of fun to drive and be pretty safe. Will post numbers and sheets when it's all done.
Old 04-23-2014, 08:45 PM
  #200
SSlobalt's Avatar
I didn't test e85 and didn't have any issues, but I live in a warm area. Admittedly, though, I haven't run E47 in over a year because it was just a pain if I wanted to drive a long distance.
Quick Reply: Piston3's LDK Swap
