PTE Turbo swap
Old Nov 9, 2012 | 04:20 PM
AyrtonSenna's Avatar
Originally Posted by AARON-SS-TC
i bet with the cam with large fuel lobes and a good tune by james/ or term or o9cs1 you would be golden. in fact you said zzp, so get their cam and have matt tune it...i bet you would be good to go man. aggressive with a good boost ramp and like 27-28psi
You think that would keep me in the 4k rpm with the 5858 or with the 6262?
Old Nov 9, 2012 | 04:28 PM
Team SS's Avatar
TTR Powered
When i was testing the TTR LNF Manifold with CCSS3. We seen a 200RPM Quicker Spool over the Stock Manifold..
Old Nov 9, 2012 | 04:40 PM
That's interesting.
Old Nov 9, 2012 | 05:02 PM
Team SS's Avatar
TTR Powered
My turbo on stock manifold would full spool around 2800-3000rpms.
Now on the TTR Manifold, It full spools around 2600-2800RPMS.
Old Nov 9, 2012 | 05:03 PM
stock turbo right?
Old Nov 9, 2012 | 05:06 PM
Team SS's Avatar
TTR Powered
Originally Posted by AyrtonSenna
stock turbo right?
BNR2871 Revised.
i'm upgrading to the 5857 pte next month.
Old Nov 9, 2012 | 05:07 PM
BNR2871 Revised.
Oh good. Let me know how you spool with the 5857
Old Nov 9, 2012 | 05:08 PM
Team SS's Avatar
TTR Powered
Will do. I just have to buy my Dejon Oil Line Kit
Old Nov 9, 2012 | 05:24 PM
Does anyone have the MSD fuel pupm ignition that Dejon sells?
Old Nov 9, 2012 | 05:29 PM
Team SS's Avatar
TTR Powered
I don't.
Old Nov 9, 2012 | 05:35 PM
  #36
Wobder if it is a good upgrade for fueling as it says
Old Nov 9, 2012 | 05:38 PM
  #37
Team SS's Avatar
TTR Powered
So far, the Stg 1 cams with LFPL are doing do.
But remember the TTR Manifold has the Option to add injectors to each runner, or Tap for meth
Old Nov 9, 2012 | 05:39 PM
  #38
rivaladore's Avatar
No, the thing is that after 420-425, the car was having fuel problems, so he had to keep it at around 410-415. I honestly believe that the tune wasn't done really properly, but a lot of things went wrong with the install anyway, and I was able to get my car back after 10 months because of a few mistake the mechanic made. That's why, no more local tuner. When I get my engine build by, for example zzp, I'm shipping them the car and I will let them do the whole job. At least I know that I will get my car back on time and with the performance that it should have
Someone let BYT touch their car
I just ditched his tune and my car is finally running right
Old Nov 9, 2012 | 05:50 PM
  #39
That's exactly right
Old Nov 10, 2012 | 12:56 AM
  #40
Nfamous60's Avatar
not sure of spool time but it might be to laggy for wut u may want for your car my friend has on on his balt and he swear he has no lag but i beg to differ.
Old Nov 10, 2012 | 01:19 AM
  #41
I don't know, I would love the 6262 but my choice of 5858 is only because of it. If I could have more or less the same spooling time, the 6262 would be my choice. At the end I'm building the engine to get the max performance possible.
Old Nov 10, 2012 | 01:23 AM
  #42
Team SS's Avatar
TTR Powered
I like the sound of that
Old Nov 10, 2012 | 01:51 AM
  #43
Thanks. When I build my engine, it will be either a 2.1 or a 2.4 setup, so I want the max performance out of it
Old Nov 10, 2012 | 09:10 AM
  #44
Nfamous60's Avatar
anyone can max performance with time and effort you must build a car at once to max performance. Motor isnt everything, your suspension has to complement your power your brakes have to handle the power and the driver needs to know how to make it work all together flawlessly, I slowed down the build of my motor to build up those areas, Yes you have a SS so some parts are more willing to handle power but not everything when you start throwing big numbers down, im starting to see now that longevity of my build is more important then maxing anything....
Old Nov 10, 2012 | 10:05 AM
  #45
All of what you mentioned are on my sig
Old Nov 10, 2012 | 01:00 PM
  #46
Nfamous60's Avatar
wasnt stating that you didnt have them meant that statement in general my bad if i misinterpret that, see alot of thread bout adding turbo kits and power very few on how to better the suspension to follow, mainly wut follows motor is a zzp trans thats bout it. how you like the black cat custom gauges, im still hesitating on pulling the trigger for purchase.
Old Nov 10, 2012 | 01:06 PM
  #47
Team SS's Avatar
TTR Powered
I have black cat custom gauges lol.
Old Nov 10, 2012 | 01:39 PM
  #48
gorgeous1!! I bought also the autometer gauges with white bezel. They have the same number style of the tachometer and they are supposed to light up blue at night like my black kat gauge. 3 of them will go on the zzp triple pod, the other 2 on the dual cluster pod. But they are charging me a tremendous price to install them. I have 5 of them and the local shop wants 100$ each
Old Nov 10, 2012 | 01:42 PM
  #49
Team SS's Avatar
TTR Powered
$100 a gauge???
Old Nov 10, 2012 | 02:10 PM
  #50
$100 a gauge???
That's what the local shops are charging. I wish I knew someone from here css.net around me that knows how to work on cars. I also have the HID projectors headlights and fog light to install. If someone of you guys don'tlive far from me and want to make someextra bucks.......
