Question for those with RPD
Old 08-06-2012, 02:02 PM
jzehren11's Avatar
So I would answer this question for myself, but my car isnt here....
but can you switch the RPD speed screen to be in KPH?? If so Im gonna be so happy!!!!
Old 08-06-2012, 02:06 PM
ei3dag3's Avatar
not that i know of. that goes off of the ecm.
Old 08-06-2012, 02:35 PM
jzehren11's Avatar
i feel like it could convert it? yes? Idk
Old 08-06-2012, 02:46 PM
ei3dag3's Avatar
maybe a dealer could flash your ecm in canada. lol
Old 08-06-2012, 03:01 PM
kdub1492's Avatar
I believe there is a section in the Manual about doing it...I think I read over it when I was trying to solve the problem I had haha
Old 08-06-2012, 03:05 PM
heeter_33's Avatar
If you change it to metric it might switch the rpd too. I don't see why it wouldn't if its changing from psi to kpa as well.
Old 08-06-2012, 03:15 PM
ei3dag3's Avatar
hmmm
true story.
you could go through the dic settings and try it.
Old 08-06-2012, 05:53 PM
Restin's Avatar
Yeah, switches everything to metric. Press info and reset buttons at the same time. Units should come up first. Hold reset for a second and cycle from English to Metric.
DIC and RPD in metric or imperial - for everything.
I think you can switch while driving
Old 08-06-2012, 11:23 PM
Stamina's Avatar
I can confirm from past experience that converting between English and Metric on the DIC switches the RPD back and forth between MPH and KPH as well.
*Unless you installed the RPD after the fact on a 2008 SS/TC, in which case it will default to metric and stay on metric regardless of DIC setting.
Old 08-07-2012, 08:03 PM
Malaclypse's Avatar
^What he said.
Old 08-07-2012, 10:55 PM
themacguy's Avatar
Originally Posted by Malaclypse
^What he said.
And again ^.
Old 08-07-2012, 11:20 PM
Stamina's Avatar
YEAH!^
Old 08-08-2012, 10:55 AM
jzehren11's Avatar
switching DIC??? how do I do that?
Old 08-08-2012, 11:08 AM
Restin's Avatar
If you mean me, I meant that when the car is moving the only setup thing you can change is the units. When parked you can use setup to change things like if the horn beeps when you press the lock button, reset oil life, etc.
Old 10-08-2012, 01:27 PM
jzehren11's Avatar
just did it and it changed everything to metric... just wanted the speed to changed but oh well.
once I get my duel interceptors Ill be set, might also get duel cluster gauge pods.
01-12-2016 12:01 AM
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 07:39 AM
09-27-2015 08:53 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Question for those with RPD
