RPD-No Data
Old Nov 23, 2010 | 03:00 PM
themacguy's Avatar
RPD-No Data
Has anybody got a "Data Not Available" message on their RPD?
I got one over top of the boost readout screen yesterday. Went away after 3 or 4 stops doing errands.
I still had boost, just no readout. Where does the boost info come from for the RPD?
Old Nov 23, 2010 | 03:04 PM
nikemax21's Avatar
Try resetting the battery to see if it fixes the issue. But I know your looking for the answer to why it happened. I just figured it might get it back up and running.
Old Nov 23, 2010 | 03:26 PM
09BlueBaltSS's Avatar
Mine does it too. Its a rpd thing due to the amount of boost. Not sure how much you run but im at ~23-24psi. Goes back to normal after a minute or two
Old Nov 23, 2010 | 03:51 PM
themacguy's Avatar
I'm running GMS1 so about 21 psi. It happened first thing in the morning when I started it. So no driving.
Like I said it went away after about 3 engine restarts and boost was fine. It looked just like the pic.
Old Nov 23, 2010 | 04:10 PM
oh. I only get it while racing or wot in third or 4th for an extended amount of time. Next time it does it try driving (not wot) if its acting up prob a sensor
Old Nov 23, 2010 | 06:20 PM
ninja44's Avatar
Your car is boosting over 22.5 psi longer than a pre determined time (can't remember how long), happens all the time with my car lol.
Old Nov 23, 2010 | 08:59 PM
yep. It takes the map sensor "out of range" and the rpd freaks out. His problem is that it popped up when he started the car
Old Nov 23, 2010 | 09:59 PM
CrystalRedSS's Avatar
This happened to me before. I started a thread on it too. Mine happened too when I started the car after leaving the bar. Cold start. It went away while I was on my way home.
Old Nov 23, 2010 | 10:17 PM
The thread can be found in the LNF Performance section under "RPD Not Showing Boost"
Old Nov 24, 2010 | 07:32 AM
themacguy's Avatar
Thanks for the heads-up.
Checked out the posts and TERM2 said it's the lower TMAP sensor input. Nexst time it happens I'll wiggle the wires and try to confirm. Then off to the dealership.
Old Nov 26, 2010 | 12:11 AM
Slobalt09's Avatar
map sensor issue... one of the map sensors is going bad, before i went stage one, i was on superchips cortex and after a few weeks i would burn a new map sensor because the stock map sensors werent supposed to read as high as 22psi...
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
JonyyB
Apr 4, 2007 08:32 PM
