RPD question
RPD question
After reading a number of threads and not finding the answer I'm lookign for....I want to know if there is a way to change the kpa to psi on the RPD specifically the boost guage, and HOW TO DO IT!! I just picked up my 2010 this weekend and can't figure out why they would even use kpa in the first place.
Just figure out the kpa.... it's not that hard plus it's much more accurate :P
Only way to do it is to switch everything to imperial units, sort of annoying as then your odo, temp, fuel economy and everything else is in imperial units to. I usually just do it every once in a while to see how much I'm boosting.
simultaneously press the info + enter buttons on your steering wheel;
your DIC should show: "reset oil?"
press "info" to scroll through your DIC options till you see one that reads something like "units" - then press enter to change your units from "metric" to "imperial" ~ your mileage will now be displayed in miles - temp will be in Fahrenheit, and pressure will be psi...
as mentioned earlier it's an all or none type thing ~ I actually always have my car in Imperial ~ and generally only change it to metric if I'm bringing the car into the dealer...
also - here's a link you might like (save the link, and save a copy of the pdf to your computer);
http://www.chevrolet.com/assets/pdf/...alt_owners.pdf
p.s. page 3-52(176) & 3-53(177)
