Service Engine Soon light, bulletin
Old Jul 9, 2008 | 01:49 PM
Cobaltss/TC's Avatar
I found this on Service info and saw some of you already having some check engine lights, here is some info on what it could be,
#08-06-04-035: LNF, Intermittent MIL/SES Light Illuminated, DTCs P0335 and/or P2610 Set (Reprogram Engine Control Module (ECM)) - (Jun 25, 2008)
Subject: LNF, Intermittent MIL/SES Light Illuminated, DTCs P0335 and/or P2610 Set (Reprogram Engine Control Module (ECM))
Models: 2008 Chevrolet Cobalt SS
2008 Pontiac Solstice GXP
2008 Saturn SKY Redline
2008 Opel GT
2008 Daewoo G2X
with ECOTEC® 2.0L I-4 VVT DI Turbocharged Engine (VIN X -- RPO LNF)
Condition
Some customers may comment on a intermittent Malfunction Indicator Lamp (MIL)/Service Engine Soon (SES) light illuminated with no engine performance concerns. Upon inspection, one or more of the following Diagnostic Trouble Codes (DTCs) will be stored in the ECM:
• DTC P0335: Crankshaft Position (CKP) Sensor Circuit
• DTC P2610: Control Module Ignition OFF Timer Performance
Correction
If routine diagnosis using SI does not reveal any obvious cause, DO NOT replace the crankshaft sensor for DTC P0335 or replace the ECM for DTC P2610. Reprogram the ECM using the latest calibration if the above concern is encountered. A revised engine calibration has been developed to address these issues. Reprogram the ECM with an updated software
Old Jul 9, 2008 | 01:53 PM
Tomtwtwtw's Avatar
Damn...you mean there's a Daewoo with this engine in it somewhere?
edit: Well, I'll be damned...
Old Jul 9, 2008 | 01:56 PM
chipsgt's Avatar
My thoughts exactly.
Old Jul 10, 2008 | 12:17 AM
soltino's Avatar
Unhappy
I would have given odds in a bar bet(-%
tino
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
grampss
Sep 27, 2015 08:51 PM
