Service ESC and Traction Control With ABS Light On
Old 05-23-2014, 05:05 PM
edmillet92's Avatar
Ok I have no idea what is going on with my car I recently changed both rear shocks and the driver side rear wheel bearing and before anyone asks yes I did plug the wire back in but now My ABS and Traction control light is on and my dash keeps Flashing Service ESC and ESC off I know it stands for Electronic Stability Control but why would it come one its been on for about 2 days now it is also flashing service Traction Control. The car is a 2008 TC. Anyone else have this happen and what can I do to fix it?
Old 05-23-2014, 05:10 PM
user 72239's Avatar
The only time my car did this was when the cable wasn't plugged back in. You sure you didn't pinch the wires?
Old 05-23-2014, 05:12 PM
edmillet92's Avatar
Yeah I am sure I double checked and everything before I put the wheel and stuff back on.
Old 05-23-2014, 05:14 PM
user 72239's Avatar
What brand was the wheel bearing you put on?
Also, did you check your fuse?
Old 05-23-2014, 05:34 PM
nobody2u's Avatar
In for answers. Once in a while my car gets this message.
Old 05-23-2014, 07:11 PM
sLAsh's Avatar
Did you make sure you got the hub with the wheel sensor? There is another one available for the base models without abs
Old 05-24-2014, 04:53 PM
edmillet92's Avatar
Yes I got the hub with the abs and I the brand is duralast I purchased it at auto zone.
I did not check any fuses though. I will do that but why would the fuse blow?
Old 05-24-2014, 05:49 PM
tomj77's Avatar
did ur wires get wet from say brake clean?
Old 05-28-2014, 04:08 PM
edmillet92's Avatar
Not that I am aware of but it is possible I am going to set up a dealer appointment and have them look at it as most salvage yards don't have ss and the wires are not listed as a part at auto zone or advanced auto.
Old 05-28-2014, 04:58 PM
Wert842's Avatar
A gm tech tool or a scanner can find out what's wrong with it. Mine was the steering angle sensor.
Old 05-29-2014, 03:36 AM
GTOworshiper9's Avatar
More then likely you have the wrong part installed. I'd return it and buy oem. Duralast is absolute garbage
Old 05-29-2014, 12:40 PM
Dubz's Avatar
I actually had this light come on last week. It was a wet rainy day and I was driving around in shitty Rockford, Illinois. However, I didn't have an ABS light come on. Computer display said "No ESC" and then "Service ESC" and my traction control turned off. Is this the same type of problem, even though ABS light didn't come on? Funny thing is when it came on, I was literally driving casually going 55 mph down a very smooth road.
Old 06-02-2014, 05:25 PM
edmillet92's Avatar
yeah I am not going to buy anything duralast anymore the appointment is for tomorrow and I am just going to have the dealership handle it.
RaginChopsuey
10-27-2015 01:27 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
09-26-2015 06:44 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: Service ESC and Traction Control With ABS Light On
