Shifting Issues
Yo,
I remember someone telling me a while back that the ss has some issues with the shifter. I have noticed that when im NLSing I grind gears alot from 1st to 2nd and 3rd to 4th. Any thoughts? |
not really too sure man but 1st to 2nd is always a hard NLS to get down. honestly i dont NLS anymore since going big turbo but i never really got 1st to 2nd down right.
The shifter and the rods / linkage are garbage, I just got mine back after a rod popping out of the plastic ball socket and bending and then later that day, popping it out at the other end but the new one didn't break thankfully. All before hitting 7300kms on the damn thing.
Shouldn't cause you to grind gears unless your linkage really needs an adjustment. Most likely clutch?? and are you sure you're putting the clutch to the floor and keeping it in the entire time you shift? I know the first time I ever NLS I didn't hold the clutch in long enough and I scared the sh*t out of myself. |
Yeah im pretty sure im not lifting up prior to the car being in the next gear. i dunno it just seems like something isnt quite right
https://www.cobaltss.net/forums/08-1...inding-187224/
read this. i had the same problem. it fixed mine. |
Originally Posted by skip_jones
(Post 5572722)
read this. i had the same problem. it fixed mine. So what is all this gear grinding actually damaging? |
Originally Posted by steviepc7
(Post 5576337)
thanks boss. ill give it a shot.
