SS tc seat questions
wonder if anyone knows if we can swap out the driver seat bottom for the passanger one. i mean just the seat i understand that the hardware and plastic sides are different. my issue is that the driver seat bottom is showing obvious wear after 40,000 miles and just wonder if i could swap them because the less used passenger seat still looks brand new.
It's a LOT of work to just separate out the cushions. I honestly don't know if the cushion can be completely separated or not. I've had my seats taken quite far apart and there were some parts that I'm not sure can be separated.
That fake suede stuff they use wears down quick, it happens on pretty much any car with seat material like that. It's just not a durable fabric. If the fibers had been a little bit longer it would probably last longer.
the suede is actually "ultralux" ~ an engineered material that looks/feels like suede.
I use upholstery cleaner;
spray it on
use a clean dry cloth to soak up, the cleaner, and lightly rub it around...
you might be surprised with how well it works.
