stalling
car wants to stall after i get into boost the rpm drops low then back up sometimes stalls completely this started happening after my zzp tune but only immediately after hard acceleration ?? its worse with ac on also blew the baffle insulation straight outta the muffler with my new found power
So I noticed that the rough idle is worse with accessories on had a few misfires and lights dimming . I think it could be the altonator or a ground. Gonna check voltage while car is idle
at idle volts are 13.5 sometimes 13.4 and with accessories on it drops to 12.8 now if i turn the wheel at the same time with ac on she goes down to 11.5 and radio lights cut out until i stop moving the wheel !!! now this is with the battery disconnected running off of alternator .
Even with the battery connected i never see more then 13.4-13.5 would this explain the rough idle and stalling ?
Originally Posted by Cobalt4209
ive heard that having cat disabled in tune can cause idle issues is this true cause all this started after my zzp tune
I understand but every car is different and some have experienced problems wth cat disabled . Either way compression test being done today after work . If that comes out good I’ll just dial in my idle with maf correction and timing tables, also copy my warm idle base tables over to cat warm base tables
Not gonna lie I’m a little worried about the compression test results
Does the RPM drop when you add accessories? I don't see why the alternator would have trouble keeping up unless the RPM is changing as the load increases. You could pull it and have it tested to know for sure. Just be certain the tester is working, I had a good alternator test bad at AutoZone a few weeks ago.
The rpm will drop when I first turn on accessories but the iac will bring it back up . It’s the voltage that drops a lot with accessories on . I looked at the zzp tune the cat base warm idle is different then the base warm idle also the min fuel pressure was changed from 2.60 to 1.80 which could explain the stalling after acceleration when I let off the gas and push in the clutch . After hard acceleration the rpm drops to 760 then one second later falls to 200-400 and most of the time completely stalls if I don’t punch in the clutch and I leave it in gear after acceleration it doesn’t stall or if I rev it to keep the rpm up
broken rocker arm and lash adjuster on exhaust valve, pulling head off to see if piston is damaged i suspect valve float from a 1-2-1 shift did this. oil coming from exhaust is from to much crank case pressure with one of the exhaust valve unable to open
