Thermostat location?
Anybody know how you're supposed to reach the petcock on the radiator to drain it? I can't get it from the top or the bottom very easily. I'm guessing it takes removing some other pieces. I could start taking stuff off, but I'd like to minimize that kind of work by knowing what exactly should come off.
I want to drain and refill the coolant, since it's been 5 years. I can "touch" the valve from the bottom, but getting a pair of pliers on it to break it loose and turn it is another story.
I was able to get it broken free using a 21mm socket. It fits nicely over the valve and made it really easy to start turning. Then I could finish turning with my fingers.
Originally Posted by NickStarr
I can’t find my coolant thermostat..
09’ LNF.
Need help. That picture on top doesn’t show anything
09’ LNF.
FYI. You have to take the fuse box off to change the thermostat. If you've never done it, I'd look up a how to because it's a royal PITA if you don't do it properly. First time I did it, I ended up bending some of the prongs for the relays and fuses and had to bend them back. Also, make sure you torque the thermostat housing properly
