Throw out bearing bolts
This seems silly but I'm not sure what to do. I'm trying to remove my old throw out bearing. I have a T30 torx extended bit so I am squarely on the bolt head and for the life of me I can't loosen any of the bolts. I've tried with a screwdriver handle and moved to a ratchet. I've slipped on one and rounded it a bit. I get all my weight on it and I just can't break these free. I tried getting some heat into it but it seems to have made no difference. I've done this job once before on a different F35 trans and I don't recall having this issue before. Any tips on removing these?
You had to weld another bolt onto them?? These things are in the ballpark of 7lb-ft, I know they have tread locker on them, but how are they so tight?! I don't remember them being this tight on a different transmission I did the exact same work on.
tread locker and easily stripped torx head. I tried welding on a bolt but i got a crappy bolt and ended up using vice grips on a bead of weld to get it off.
i got very lucky with mine and managed to strip all 3 heads lmfao i just used a screwdriver and a hammer and dig into the head of the bolt and tap it counter clockwise. the total way to avoid this is to use a impact screwdriver and if she dont turn she need heat or u snap torx bit or round bolt :/
You can try to put the bit in and hit it with a rubber mallet or dead blow hammer. You just need to shock/break the grip. If you had an impact, it essentially does the same thing... but that's obviously a little riskier.
These things are a life saver. Its a must for torx bolts.
https://www.grainger.com/product/1AT...5Q7YX:20500731
This search has brought me to a Craftsman one for $20 and a Pittsburgh (Harbor Freight) one for $10. Not sure why I never found them in my previous searches.
My local Lowe's has them in-stock (bonus: I get a 10% veteran discount at Lowe's).
CRAFTSMAN Hand Impact Driver CMMT14104
So I ended up notching the bolt heads with an angle grinder, then I used the hand impact with a flathead bit on it and I got them both out without too much difficulty. Thanks for all the advice everyone!
i didnt look at this thread for a few days but holyy **** i didnt mean to hit it wit a impact wrench haha i meant wit a impact driver like the one they linked..... omg dude ur gonna have to do wat i said wit the screwdriver and just dig into the bolt haha editing cuz i didnt read that u got them out but u basically did my method lol
https://www.thatgmpartsguy.com/p-mu3...olts-90541173b
You have to order 3 as they come individually wrapped.
I'll try to pull one of mine and measure it. The last TOB change that I did, I didn't use the stock bolts (because they strip out easily), but instead opted for stainless socket cap screws, which you can grab at any Lowe's/Home Depot - usually for less than the cost of 1 bolt from GM. I want to say they were something like M6-1.00 x 15... but don't trust that just yet.
My guess is that they used a soft metal so that if they're installed wrong (cross-threaded), it's the bolt that fails; but that's entirely just a guess. I wondered the same thing with the special blue bolts that they used for the S/C pulley in the GM Stage 2 kits for LSJ's... those bolts had a special anti-tamper head and would strip out SUPER easily. At least in that case, the reasoning is so it's easier to know when to deny warranty because of modification.
DualSpoolinSS's
Jun 30, 2013 04:35 AM
