Tire Sensor Issue
Old May 28, 2013 | 12:20 PM
jgerma01's Avatar
Tire Sensor Issue
I just rotated my tires recently and am trying to rest the TPMS system. Unfortunately my passenger side front tire will not "relearn" when letting air out of the tire. I am assuming the sensor is bad, is there anything I can do to besides replacing the sensor?
Old May 28, 2013 | 08:49 PM
Restin's Avatar
If all you did was rotate the tires, the sensor "should" be good, unless you rotated just as the battery died (otherwise you should have had a TPMS warning before). And, of course, make sure you are letting enough air out for enough time (have compressed air ready)
Only thing I can suggest (and dumb idea) is when you get to the passenger side front, try letting the air out of a different tire to make sure the computer is ok - can't imagine why it wouldn't be, though.
Old May 29, 2013 | 07:20 PM
tomj77's Avatar
Try putting air in, it sometimes won't beep even after letting air in or out for the 8 seconds, just stop putting air out after 8 seconds and wait for the beep, uv seen it take close to half a minute to beep
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
jmelton327
Sep 26, 2015 10:04 PM
