trifecta special request
What special requests are there for a turbo ss. As of right now i want No throttle delay and the ecp tune what are other good requests? Can someone please list all possible special requests? Whats a good safe number to raise the rev limiter to?
considering our throttle bodies are all electronic, there's still going to be that delay. ecp? on stock springs and balance shafts... maybe 7k... remember, you're turbo'd, you drop boost at higher rpms (unless i'm mistaken..) you can change your fuel trims to run more rich, advance your timing to a point where you get maximum power and no kr, adjust your wastegate for more boost.
You can change the launch control RPM. Increase boost limit in 1st. Tune for E85. Remove the top speed limiter. Tune for 93 octane. Raise boost to 24-25 psi...
I wouldn't raise the RPM limit though. Unless you do supporting mods and want to trap in 3rd.
You can increase the throttle response a good amount, it's delayed factory. You can get select-a-tune on cruise control or on competitive mode as the switch. I don't recommend raising the rev-limiter usually, no need to. You can adjust launch control yourself using ezflash. ECP is a new feature you can ask for if you want to try it out. We've got a few new things that we're trying out on the LNF that we aren't ready to talk about yet, but they will be big when we do come out with them.
Yes you can request that. If you order from me you can get the tune cheaper than from Trifecta direct.
