TSB's
ODI - Office of Defects Investigation
There are 14 of them for 2008.
Make : CHEVROLET Model : COBALT SS Year : 2008
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Number : SB-09-09-40-003 Date of Bulletin : AUG 01, 2009
NHTSA Item Number : 10032334
Component : INTERIOR LIGHTING
Summary :
CHEVROLET/PONTIAC: SIR/AIRBAG LIGHT ILLUMINATED, DTC B0081 AND PASSENGER PRESENCE SYSTEM (PPS) CODE 23 STORED (REPLACE PASSENGER SEAT BELT RETRACTOR AND RE-ROUTE WIRE HARNESS). *PE
Component : AIR BAGS
Summary :
Service Bulletin Number : SB-09126 Date of Bulletin : JUL 01, 2009
NHTSA Item Number : 10032186
Component : POWER TRAIN:MANUAL TRANSMISSION
Summary :
CHEVROLET: SERVICE UPDATE FOR INVENTORY AND CUSTOMER VEHICLES CHARGE AIR COOLER INLET DUCT DETACHMENT - EXPIRES WITH BASE WARRANTY. *PE
Service Bulletin Number : SB-09-06-93-002 Date of Bulletin : JUN 01, 2009
NHTSA Item Number : 10032461
Component : ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:TURBO-CHARGER
Summary :
DAEWOO/OPEL/SATURN/PONTIAC/CHEVROLET: TURBOCHARGER HOUSING INLET FLANGE CRACKS IN PARTITION WALL. *PE
Component : ENGINE AND ENGINE COOLING:ENGINE:OTHER FUEL TYPES:TURBO-CHARGER
Summary :
Service Bulletin Number : PIP-4638 Date of Bulletin : MAY 01, 2009
NHTSA Item Number : 10032558
Summary :
CHEVROLET: DIFFICULT TO SHIFT OR UNABLE TO SELECT ALL GEARS. THE TRANSMISSION IS DIFFICULT TO SHIFT AND/OR IT CANNOT BE SHIFTED INTO ALL GEARS. THIS CONDITION MAY BE CAUSED BY A LOCATOR PIN LEFT IN PLACE THAT WAS MEANT TO BE REMOVED AT THE ASSEMBLY PLANT OR A SHIFT CABLE OUT OF POSITION. (COBALT SS/HHR SS). *PE
Service Bulletin Number : SB-08-06-04-035A Date of Bulletin : MAY 01, 2009
NHTSA Item Number : 10030647
Summary :
GENERAL MOTORS: AN INTERMITTENT MALFUNCTION INDICATOR LAMP (MIL)/SERVICE ENGINE SOON (SES) LIGHT ILLUMINATED WITH NO ENGINE PERFORMANCE CONCERNS. UPON INSPECTION, ONE OR MORE OF THE FOLLOWING DIAGNOSTIC TROUBLE CODES (DTCS) WILL BE STORED IN THE ECM-DTC P0335 CRANKSHAFT POSITION (CKP) SENSOR CIRCUIT; DTC P2610 CONTROL MODULE IGNITION OFF TIMER PERFORMANCE. *PE
Service Bulletin Number : SB-09-09-41-003 Date of Bulletin : MAY 01, 2009
NHTSA Item Number : 10030646
Summary :
CHEVROLET/PONTIAC: THE SIR/AIRBAG LIGHT IS ILLUMINATED. UPON INVESTIGATION, THE TECHNICIAN MAY FIND DTC B0081 SET. *PE
Check to Request Research. Submit below.
Service Bulletin Number : TSB-09-09-41-002 Date of Bulletin : APR 01, 2009
NHTSA Item Number : 10030146
Summary :
GENERAL MOTORS: SIR/AIRBAG LIGHT ILLUMINATED, PASSENGER PRESENCE SYSTEM (PPS) DTCS 023, 024, 063, 064, 065 SET (INSPECT PPS SYSTEM WIRING AND/OR CONNECTORS). *PE
Service Bulletin Number : TB-PIP-4520 Date of Bulletin : NOV 01, 2008
NHTSA Item Number : 10030004
Summary :
GENERAL MOTORS: TECH MAY ENCOUNTER A VEHICLE WITH A LOW BOOST/POWER CONDITION AND/OR DTC P0299 AND OR P0101 SETTING. THIS MAY BE THE RESULT OF A CRACKED OR BROKEN FITTING AT THE TURBOCHARGER ASSEMBLY. *PE
Service Bulletin Number : PIP-4485 Date of Bulletin : OCT 01, 2008
NHTSA Item Number : 10026690
Component : ENGINE AND ENGINE COOLING:COOLING SYSTEM:HOSE
Summary :
GMC: LOW BOOST, REDUCED POWER AND/OR DTC ON CERTAIN 2008-09 COBALT SS. INSPECT THE RIGHT SIDE CAC (CHARGE AIR COOLER) PIPE FOR CONTACT ON RADIATOR SUPPORT BOLT. *PE
Component : ENGINE AND ENGINE COOLING:COOLING SYSTEM:RADIATOR ASSEMBLY
Summary :
Service Bulletin Number : PB-08200 Date of Bulletin : JUN 01, 2008
NHTSA Item Number : 10029007
Summary :
GENERAL MOTORS: ENGINE OIL PAN DRAIN PLUG THREAD INSERT LOOSE OR DAMAGED; INSPECT/INSTALL NEW INSERT. MAY HAVE AN UNDERSIZE ENGINE OIL PAN DRAIN PLUG THREAD INSERT. *PE
Service Bulletin Number : 08-200 Date of Bulletin : JUN 01, 2008
NHTSA Item Number : 10026606
Summary :
GMC: ENGINE OIL PAN DRAIN PLUG THREAD INSERT LOOSE OR DAMAGED-INSPECT/INSTALL NEW INSERT. VEHICLES MAY HAVE AN UNDERSIZE ENGINE OIL PAN DRAIN PLUG THREAD INSERT THAT WILL BE INSTALLED TOO FAR INTO THE OIL PAN HOLE. *PE CSC LETTER WAS RECEIVED. UPDATED 12/1/08. *PE
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
satisfied
Oct 19, 2015 12:35 AM
Adam144
Sep 3, 2015 07:48 PM
jbounce
Aug 29, 2007 09:27 PM
my_bd
Nov 18, 2006 08:23 PM
