tunning my cobalt ss newbie here
Hey guys,
Weird question due to my last of knowledge in this category.
To begin with I am getting a 3" down pipe, k&n intake, intercooler and piping installed onto my 08.
I have a local dyno here that says for 1-2 hours with a tune they will give me a good tune for 600 bucks.
First question,
Do I need to by JP tuner or something, or can the dyno tune take out the learn down feature and all that.
Q#2
What support mods would I need for the car with these mods,
Q#3
And what gains should I get so I know the dyno is not screwing me.
Any advice or heads up would be nice and thank you in advance.
First question,
Q#2
Q#3
Welcome!
1) Best bet would most likely be finding a reliable tuner here for a fraction of the cost using HPTuners. Dyno tuning doesn't allow you to disable learndown (IIRC)
2) 3 Bar MAP sensor would help for more accurate boost reading above stock tune. Intake, tune, MAP sensors, and intercooler/piping are the big ones up front.
3) Approx 300 to the wheel...
https://www.cobaltss.net/forums/08-1...d-me%5D-82531/
awesome guide for LNF builds in the link above
So I don't have to buy a zzp ecm or HP tuner if I plan to just use a dyno?
Or should I buy a zzp ecm and then run it at the dyno to solidify the tune?
(I'm installing them all at once then tuning it so I don't mess with anything)
Welcome!
Is a bov a need? Or should I just keep it how it is?
^CED has a "plug and play" 3bar map sensor kit and its worth every penny so you don't have to cut and solder your new connections. what i would do is pay your tuner tell them the mods you are going to be running and they will send you a base file to run. you must have a tune for the 3bar map sensors.BOV is not needed and requires more modifications then its really worth in my opinion but some people love the sound.
P.S. Should I get the intercooler with the piping? or is that more for higher hp gains? Im looking at being a sleeper and won't be messing with the exhaust. But I want to eat anything close to a 5.0 coyote mustang.
basically I want to be able to run 12 second 1/4 mile.
mid 12 will be hard with a fwd manual trans car but you will sure have the trap speed of a 12 second car! with a K&N intake these cars make alot of turbo noise even on stock turbo and bpv. the intercooler kit is more of a reliability upgrade. what i would suggest to you is get basic bolt on and a tune and go from there, you might be happy or get bit by the modding bug . an intake, catless dp, 3 bar map sensors and tune are going to be your priority if you are after power
Well I was looking at the tuners list
https://www.cobaltss.net/forums/tuni...cations-86603/
and well its like 3 years old so I am worried the guy in dayton wickedss2005 isn't doing them anymore but I have to contact him I guess. Dayton is like 10 minutes away from me.
I allready have the mod bug man. I came from a very long line of modding cars, and never am happy until the cars gets scary. However, with the motivation of this being a daily driver. I don't want to kill myself.
I am a drag strip wannabe king, and run at kilcare all the time. However it has been closed so I have to get my fix on closed roads till I find a new strip.
neat thing is about hp tuners is you don't need to be geographically close to your tuner, i live in basically the most western part of Canada and my tuner is in florida. 09CobaltSS1, terminator2, area47 are really reputable tuners to name a few. KM043 is starting to get more lnf tunes under his belt and is worth PMing as well
Curious if I should buy an Hp Tuner now or see if anyone close by has one.
buy hp tuners as an investment so you can datalog and change the tune when ever you want. there are alot of things tuners have to look out for not just A/F. i would trust anyone of those tuners mentioned above but i am not here to play favorites
On that note anyone got an HP tuner around the Dayton Ohio area haha
The stock bpv is more than capable of handling pretty much whatever boost level you can throw at it. Put it this way, ALL efr turbos all the way from the 6255 all the way up to the 9180 use the exact same bpv.
The rubber diaphragm on the stock BPV can tear after a while, but i'm talking lots of years, at high boost and high temps. But almost everything will wear out eventually.
justify it how you want. engineers at borg warner are not stupid, they sure as hell didn't go though all of R&D making the EFR from the ground and cheap out on the bpv.
