TWM STS Wont Fit?!
TWM STS Wont Fit?!
can anybody tell me what the difference is between the ss/tc and the ss/sc as far as the shifter setup? i have a twm sts in my current 06 ss/sc and the site sells ss/tc and ss/sc sts's separate from eachother.
Same part number.
They're the same shift assemblies and almost the same transmission with a change in the final drive ratio.
Originally Posted by TWM shopping cart
Cobalt SS/SC and SS/TC Short Shifter (Part 4507) (Aluminum Series, M1 Abrams Shift Knob RL , No engraving, None )
identical. measure the shifter I did have one machined wrong; it would not fit correctly and could not adjust it for reverse withouth grinding the shifter housing. TWM stepped up with new shifter no problem; no complaints.
If you dont have one get one. The stock shifter feels so vague and rough. Once the twm is adjusted properly it's smooth as butter. Night and day difference and the sifter height is the same only with reduced throws so it works awesome.
i currently have one so ya i want to tranfer it from one the the other
Delta coupe
Sep 30, 2015 08:11 AM
