What exactly does the stability control do on the turbo SS?
Like the title says.......what does it do and by turning it off, what doesthat do? What are the advantages to shutting it off or keeping it off
Shutting traction control off?
What r the advantages to turning off the traction control! If I do shut it off doesn't that mean that I will be more **** to wheel spin?
yah you can really feel esc on or off when you take big loops going somewhat fast. I've taken a slightly hard turn in a cul de sac and could literally feel when the outer rear brake would engage and dis-engage soflty to prevent my rear-end from skidding or sliding. With esc on you can take corners comfortably fast while knowing you won't slide out. But the second you take esc off, you can really feel the car and its limits. I recommend only taking esc off during race applications or toying around "In a safe area" that is.
Tried a google search and this is what I found.
DIC Warnings and Messages: DIC Warnings and Messages - Instrument Panel - Chevrolet Cobalt owners manual - Cobalt Cobalt - Chevrolet manuals
Traction control: Traction Control System (TCS) - Driving Your Vehicle - Chevrolet Cobalt owners manual - Cobalt Cobalt - Chevrolet manuals
Electronic Stability Control: Electronic Stability Control (ESC)/ Traction Control System (TCS) Indicator/Warning Light - Instrument Panel - Chevrolet Cobalt owners manual - Cobalt Cobalt - Chevrolet manuals
Comp Mode: Competitive Driving Mode (SS Models Only) - Driving Your Vehicle - Chevrolet Cobalt owners manual - Cobalt Cobalt - Chevrolet manuals
AWD > FWD
Ya, to give you an idea of how powerful the esc can be at time, I used to use it to make sharp 90* turns into my driveway in the snow. I got used to when it would kick in, and would literally drift into my driveway just by turning the wheel. The esc would only hit the rear brakes and throw me around the corner. Almost caused me to spin out Once in the winter
You have a freak of nature then, I've purposely ripped my handbrake in the ice/snow with ESC active, and the car very effectively corrects the slide.
This. It uses input from numerous sensors around the car to determine requested direction and the direction it believes the vehicle is moving. If the two cross a threshold, the Stability Control begins applying the brakes (I think only rear?) and cutting throttle input to make requested and actual direction as close as possible without risking making the car unstable in the other direction, etc.
Putting the car into comp mode lessens the sensitivity and strength of esc without fully disabling as well.
You can disable it completly by unplugging the rear wheel sensors plug under the car by the fuel filter. There is a plug that comes through the body under the rear seats that contains i believe three plugs. trace it back a couple feet and you can see which one goes to the wheels. Unplug it and you dont have to worry about any ESC what so ever and dont have to hit the button either. You do get a T/C light on the dash and a ABS light since it has no clue whats going on back there anymore. Be careful if you do this, You have no computer help with stability or breaks so your basically driving a 350hp go cart.
Stability control engages the inner rear brake to reduce understeer and engages the outer front brake to reduce oversteer.
Last edited by V8Rumble; 07-17-2011 at 02:29 PM. Reason: outer on oversteer, not inner
Already said but I'll throw in what I know. Traction control is used when the wheels slip during acceleration-it applies brake. Stability control utilizes all 4 brakes and throttle in the case of sliding. ABS taps the brakes at a REALLY fast rate in order to stop the wheels from locking up, faster then it is possible for a human to pump the brakes.
For me, traction and stability control are pretty much useless, I know my car well enough to be able to handle sliding more efficiently then just braking until i stop sliding. It actually gets annoying on back roads around my house that I usually haul ass around, I'll be going around a corner in complete control and stability control will reduce throttle and I can feel certain wheels braking for no apparent reason lol. I also turn both off when autocrossing, they really are not efficient at all, more of a safety precaution. ABS is very useful and should always be used in my opinion though
Traction control is very useful in more powerful RWD cars however, in the Cobra it does wonders if you just get the urge to mash it lol
How do you guys drive around normally with the esc / tcs? Both on? Both off? One on one off?
I normally drive around on a dry day with just traction control off. On a wet day, traction control is on. I only deactivate ESC and TC (by holding down the TC button for like 10 seconds, for those who didn't know) if I want to race someone. After that, I go back to just traction control off. If I just want to activate my tune and mess around without racing, I'll put it into competitive mode.
AWD > FWD
If you're just driving around normally, there's no reason to bother turning off the esc/tcs. Just leave them on, if you get in a race, then turn of traction control. The only time the ESC should need to be turned off is at a road course/ autocross.
