What RPM do you shift?
So I'm still getting accustomed to having a 4cyl car again. I was used to my old 5 speed 3.1L Cavalier from a few years ago, which I would shift no higher than 2500rpm under normal driving. Then there was the Grand Prix, it was auto, but I was used to seeing the revs at 1500 at cruising speed.
Now I find I need to get accustomed to shifting at higher than 2500rpm, mainly because I find coming out of 1st at 2500 leaves you at about 1000 in second...then you have to pin it to get any throttle response, which causes the boost to kick you in the ass and sometimes spin your tires, especially if you're going around a corner while doing this.
So my question to you is where do you find it most comfortable to shift? I'm starting to like about 3000-3200 from 1 to 2, about 2800 from 2-3 and pretty much anything above 2500 from 3-4.
The way I figure it, although the RPM cutout is 6300, I think shifts at even 3500 aren't that unreasonable...4 cylinder cars are made to rev...especially imports!
2000 rpm still only an average of 18.9 mpg with the most ridiculous granny shifting you'll ever see... going 35mph im in 6th gear at 1200rpm its basically idling haha
sorry i will contribute to this thread lol... In my ss/sc I used to shift at 3500-4000 for the 1st to 2nd shift then 2500-3000 for all other gears. I found that it would bog out a bit if you shift below 2500 for 1st to 2nd shift...
try to rev match a bit before u raise clutch... my rpms dont drop entirely that much when i change gear, i shift out of 1st at about 2500-2700 and can catch second at about 1800. and i dont ride the clutch either.
i'll say it again. there's more to getting good gas mileage than how low the rpms are. you can get better mileage at a higher rpm. many times at lower rpms, even going up a slight hill you will be boosting. so what's better, 2k rpms and 5 psi or 3-4krpms and vacuum.
I don't really pay attention to RPM. It's more of a sound/feel thing when I'm just putting around. I can tell you though that once I hit 45mph, I'm in 5th.
So, I'd say @ 15mph I shift into 2nd, @ 25 I hit 3rd, @ 35 I hit 4th, and @ 45 I hit 5th.
When I'm racing, 6100~6200 is when I shift.
FWIW - I get best mileage on a flat surface going 40~45mph in 5th.
