What tune?
Old Dec 14, 2013 | 04:46 PM
Trackguy's Avatar
What tune?
I bought a 08 ss about two months ago. My modifications are: K&N short ram intake, Treadstone TR12 intercooler, Turboxs RF exhaust, Treadstone Charge pipping( upper and lower), Turboxs 3in downpipe, and Clutchmaster Stage 3 clutch with lightweight flywheel. Its time for a tune. I want more boost, better ratios, better idle, and I need to keep some function. Which tune should I get?
ZZP? Trifecta? or drop the money on a HP? or wait?
Any input would be great!
Old Dec 14, 2013 | 05:06 PM
andrewcarr1993's Avatar
Go buy HP tuners and then have someone remote tune it, you'll have the best results that way.
Old Dec 14, 2013 | 05:22 PM
blueLNFftw's Avatar
HP Tuners.
Period.
Old Dec 14, 2013 | 05:24 PM
Trackguy's Avatar
How long does it take for someone to remote tune it? I am a college athlete so time is important. I would really like to just install a PCM and go.
Old Dec 14, 2013 | 05:39 PM
kzak104's Avatar
lol what does that have to do with anything, its not like your car will be down if its not tuned...
trifecta is fine.
Old Dec 14, 2013 | 05:42 PM
huckernage's Avatar
look at my sign
A base tune with a few hours of logging and getting updates until it's perfected.
Old Dec 14, 2013 | 05:48 PM
07cobaltLScoupe's Avatar
with those mods are you sure it doesn't have a tune already?
Old Dec 14, 2013 | 06:16 PM
Trackguy's Avatar
trifecta is fine.
Very true. lol but if i am going to do a tune I dont have the time to get with someone and remote tune it and update it. Im not worried about my car being down. Trifecta is probably what I will do. 23 lbs sounds awesome. Any problems with it?
07cobaltLScoupe, no it dosnt I did all the work during Thanksgiving week.
Old Dec 14, 2013 | 07:33 PM
alerosaint's Avatar
You got to pay to play. ..so unless you got someone to do the logging for you your gonna have to log to get the best out your car. That goes for trifecta or hptune.
The time have to go in. ..If you don't want to deal with that I'm sure there are some programmers out for the TC with a cookie cutter tune that will give you a modest performance boost like sct.
Old Dec 14, 2013 | 08:46 PM
09CobaltSS1's Avatar
If you're not willing to take the time to properly allow a tuner to dial everything in the way it needs to be done, then don't even bother. A good tune is the lifeblood of your engine and can/will make or break the life span and durability of the engine. Not to mention just the overall drivability of the car. If your time so too sacred, then just remove your CAI, do an airbox mod, go GMS1 and call it a day.
Old Dec 16, 2013 | 12:08 PM
Econobox's Avatar
Pretty harsh. There are tens of thousands of cars with off the shelf tuning. The rate of exploded cars (by a bad custom tune) is way higher than the rate of off the shelf conservative tunes. Not to say a bad off the shelf tune is any less likely though - a bad tune is a bad tune.
That said, a decent to good custom tune is better than any off the shelf option. It's just more effort and availability is lower. Probably oversimplifying, but you are able to gain power more efficiently by adjusting the levels to a more moderate degree, over a conservative one that has to take into account that some cars might not be in peak condition. Sad to say a lot of mailed custom tunes are literally exactly the same as an off the shelf tune for the same modifications - once the logs are viewed and it's apparent the car is within the limits of the base-custom tune. Again this doesn't mean this is how they all are.
The only kind of custom tuning I like to do in the past in right there, in person, on a dyno. This isn't possible for a lot of people but if you can manage it I'd recommend making the effort. On the last car I did this on I had a "stage 2" tune (Cobb) making around 290 awhp, and simply getting it custom tuned by a good shop I gained 32 whp and a lot of throttle response. Plus it felt more "raw" for lack of a better word, ready to GO at a moments notice. I traveled out of state to do this and I really didn't want to but it was worth every penny and every minute spent.
And finally, I say all this and now I will tell you I have a trfiecta tune. Why? I had my bolt ons and I wanted them to be utilized by a conservative tune until I found a good shop to do a tune. I'm debating holding off for a new turbo given my cars mileage. But it will be done.
To review the trifecta, it works. It smells a tad, tad tad bit rich, if anything (ultra scientific). The difference is pretty astounding between base tune and the trifecta with bolt ons. Being able to toggle with the cruise control button is nice, but it really shows you the difference the tune makes as well.
As a side note, I wanted my tune to be deactivated with the cruise control on, versus off. My reasoning was if I was using cruise control I'd rather the tune be off than on (default is on - on). If you leave your cruise control button on when you flash your ecm it reverses, so that cruise control off is trifecta tune on. I'm not sure if this is documented or not but if it isn't there you go. However this might be a moot point because my gas mileage didn't change from base tune to trifecta, like at all. I average 24 mpg mixed, which is exactly what I was at before.
Whatever you decide you will be very happy with the difference a tune makes. It really makes use of the mods you just did, where as the base ecm simply does not.
Old Dec 16, 2013 | 10:44 PM
TCBalt09's Avatar
As a dealer, I can say the Trifecta tune defaults to CC on tune off. CC off tune on. Default setting when ordering aswell.
Old Dec 16, 2013 | 11:06 PM
Kurisutofa's Avatar
Would you recommend HP Tuners over somebody who wants to slowly modify/tune their car? Or would Trifecta do the job? From what I think I am understanding HP Tuners is good if you're wanting to keep tuning the car but Trifecta is good if you're just wanting a tune and nothing special past basic bolt ons?
Old Dec 17, 2013 | 03:33 AM
TCBalt09's Avatar
I would go trifecta. I have basic bolt ons and couldn't be happier with the Trifecta. HPT is overpriced IMHO. You have to pay for software, credits, then whatever the tuner charges. The that can all add up to 500-600. IMHO Trifecta makes more sense financially and for what I wanted.
Old Dec 17, 2013 | 09:07 AM
Wert842's Avatar
The support and feedback of trifecta is complete garbage. I've switched to the other side coming from trifecta and I'd recommend hp over trifecta any day of the week. It may make sense financially but in the long run the HP route could pay off if you take the time to understand it...
Old Dec 17, 2013 | 11:58 AM
Kurisutofa's Avatar
So HP is 500-600 out the door, what about Trifecta is most cases? What made you switch over, Wert842?
Old Dec 17, 2013 | 12:30 PM
Wert842's Avatar
Price really all depends on if you can ****** a good deal on a used suite or not. Tuners prices are like $300 for a remote tune.
I made the switch cause I got a decent deal on a suite and somewhere down the lines it would be a great trade to learn. Another reason why I made the switch is that, when you email trifecta questions, you get bland and bold answers that really don't help you. They are straight forward tuning and don't give you feedback. Even when I bought trifecta they were running a promotion of $100 retunes for any upgrade you do to the car and then when I went bigger turbo, they asked for the full $300. Didn't make sense to me.
If you do go HP though, choose your tuner wisely.
Old Dec 17, 2013 | 12:40 PM
blueLNFftw's Avatar
Not only this, Trifecta locks parameters so you can't see or log them either. I have an underlying duty cycle issue I was completely unaware of because my Trifecta tune would not let me see Duty Cycle, TPS, KR, or MAP. Switching to HP was one of the best choices I made for my car.
Old Dec 17, 2013 | 12:41 PM
alerosaint's Avatar
^^ dang...my retunes are free. But yeah having. HpT allow me to know my about the car. Am I a tuner? No, but my wisdom has increased. I even tweak my own mafs! Hey I'm proud of that...don't judge lol.
The main problem the op was saying he don't have the time to get logs. So hp or trifecta wouldn't be wise if he don't have the time to log properly. Like 09cobalt say he is better off with gms1.
Old Dec 17, 2013 | 04:03 PM
m33pm33p's Avatar
Luls wert. Bland questions because the majority of people have no ******* clue what anything means anyway. A lot of Vince's procedures are due to engine safety/people being idiots, and general legal guide lines.
There is nothing wrong with trifecta if you are patient. If you don't have time to data log either way you shouldn't get a custom tune.
There is no downtime with trifecta if you switch back to stock mode when waiting for your update file so that is m00t as well. People complaining about time don't realize Vince serves thousands of people a day, where as your typical hp tuner might do one per week.
Locking parameters isn't an issue if you have the proper gauges, which you should have to monitor a tuned car anyway right?
Old Dec 17, 2013 | 07:21 PM
TCBalt09's Avatar
I can see all those sensors and I use basic android torque so I'm not sure what your saying. Another thing with HPT is selecting a tuner. With HPT you have to go with someone that essentially just has Street credit vs Trifecta being a company. Retunes for major mods like turbo swaps are $100-120 IIRC but they are definitely not $300
Cost of a Trifecta tune through a dealer is about $350 for the custom tune or $200 for the budget
Old Dec 17, 2013 | 07:31 PM
HP > Trifecta
Old Dec 17, 2013 | 08:12 PM
.... and so the Trifecta vs HPT debate continues.
OP, please just get a GMS1 so this doesn't carry on.. lol
Old Dec 17, 2013 | 08:19 PM
Shanedude's Avatar
GMS1 is quite enough power for the regular guy. And warranty approved.
