Wtf!
Old Jul 21, 2010 | 03:39 PM
GOONIE's Avatar
Wtf!
so i was driving my car on july 4th and it was running great until it decided to stall out...so i started checking it out and when i unpluged the MAF and the engine stayed running and i was able to drive it (without any boost) so i figured it was the sensor that was shot so i bought a new one and replaced it but still the same problem it will idle up and slowly go down until it stalls....any help or opinions on what the hell is going on?
Old Jul 21, 2010 | 06:14 PM
SSlobalt's Avatar
We're gonna need more info. Sounds like a vac leak or a boost leak.
Old Jul 21, 2010 | 08:20 PM
GOONIE's Avatar
how would i find out should i get it hooked up to a computer or would that not tell me
Old Jul 21, 2010 | 08:22 PM
importkiller's Avatar
See if they can pull any codes. Other than that check all sensors for damage and check boost piping and vacume hoses.
Old Jul 21, 2010 | 08:38 PM
beast10007's Avatar
check your rubber hose's too they might have popped off.
when you where driving was this right after you let of the gas?
code's would be sweet!!
look over every thing!
good news is it sounds like a cheap fix
Old Jul 21, 2010 | 09:58 PM
metalmedic's Avatar
maf sensor could still be bad.. they re-build them and sell them over it happened to me...
Old Jul 21, 2010 | 10:32 PM
SS-Performance-RS's Avatar
Take it to the dealer. Warranty FTW!
Old Jul 21, 2010 | 10:40 PM
chris88z24's Avatar
Are the turbocharged models really this unreliable? Seems like everybody who owns one, both people I know in person and through forums, have had nothing but powertrain-related issues with them.
Old Jul 21, 2010 | 10:45 PM
Not really, got 23000 miles on mine and no drivetrain problems. Knock on wood
Old Jul 21, 2010 | 10:55 PM
bamaboy22's Avatar
My 2010 only has a loud noise from brakeing. Other then that wipers?
Old Jul 22, 2010 | 11:56 AM
GOONIE's Avatar
okay guys codes are as followed P0090 and P0100 any info!
Old Jul 22, 2010 | 12:15 PM
Wickedlsj's Avatar
Yes, you have to occasionally run it on the blood of a virgin or unicorn tears to keep problems from developing.
Old Jul 22, 2010 | 12:22 PM
ghostss09's Avatar
make sure your intake is still sealed correctly
no guy, what his problem is is his cars breathing, thats the problem
thats from your intake not being attached, i had the same problem when i put on my aftermarket intake, check your pipes
Old Jul 22, 2010 | 12:28 PM
GOONIE's Avatar
so make sure my intake is on right and charge pipes?
Old Jul 22, 2010 | 12:31 PM
Jazer's Avatar
It could have thrown those codes after you decided to pull the MAF out as well.. May not be directly related to the problem you are having.
ghostss09's Avatar
yep that should be your problem if not then you do need to take it to the dealership. but from how you desribed it, it sounds like your intake
Old Jul 22, 2010 | 12:45 PM
GOONIE's Avatar
so what do the codes mean
Old Jul 22, 2010 | 12:49 PM
ghostss09's Avatar
jazer is probably right, you could have thrown codes when you pulled out the MAF, you can get those thrown codes deleted and the check engine light will go away, if you want to know what they mean then google them, i dont remember what they mean,
Old Jul 22, 2010 | 12:58 PM
GOONIE's Avatar
i had the guy delete the codes n my cel went away but wen i plugged the maf back in it still stalled
Old Jul 22, 2010 | 01:03 PM
ghostss09's Avatar
pipes are fine? what about your intercooler, and holes? make sure everything is tight
Old Jul 22, 2010 | 01:21 PM
68Vette's Avatar
Mass Air Flow(MAF) Sensor P0100 / Primary Malfunction = sensor signal time period
High Pressure Fuel Volume Control Valve Circuit rationality P0090 Primary malfunction =
Voltage test pulse - off command within window.
This is what the codes are listed as, hope it helps.
Old Jul 22, 2010 | 01:48 PM
GOONIE's Avatar
what do i do about them to get it runnning to full potential without taking it to a dealer dnt realy have the funds to send it to GM
Old Jul 22, 2010 | 08:01 PM
SSlobalt's Avatar
Gotta be a boost leak. You need to pressure test it, but you'll need a compressor and a boost leak jig to do it. Did this problem occur after letting off a WOT run? I assume it did because it was July 4th. You probably cracked the intercooler endtank. It's unfortunately a common problem with high boost cars.
Cobalt08LS
Jun 19, 2016 07:29 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
Blackey2005
Sep 11, 2011 01:06 AM
