108k Miles on LNF, installing ZFR, should I timing chain?
Old May 2, 2017 | 02:11 PM
Silverbullets's Avatar
Hello all, I am installing a ZFR on my 09 TC. It has 108k miles. Should I 100% replace the timing chain?
Does this kit suffice? https://www.gmpartscenter.net/oe-gm/...xw5RoC-Jzw_wcB
Or should I get everything on this CED kit: http://www.crateenginedepot.com/Lnf-...it-P24044.aspx
Thanks,
Old May 2, 2017 | 02:23 PM
I haven't heard if that kit from rockauto is any good but I personally would stick with oem. I'm kinda in your shoes I wanna upgrade my cams tho so if I do that might as well do the timing since the engine will be open. I would just do it for peace of mind since you will be pushing the car harder
Old May 2, 2017 | 02:39 PM
I think youre right. Sorry can you check the links I posted again. The first one is just the chain and what not. Do i need all of that in the second link?
Old May 2, 2017 | 03:23 PM
user 72239's Avatar
I bought the cloyes kit for my LSJ. was marginally cheaper than CED and was the same quality.
Old May 2, 2017 | 03:25 PM
Tdubbs's Avatar
I would get the deluxe kit from CED. The last thing you want to do is cheap out on something like the timing set, especially if you just dropped bigger money than that on a new turbo. Best case if you don'tget the better kit is it jumps time and you have to tear it all back apart again to do it right. Worst case you'll be looking for a new motor in short order.
Edit: That's just me though, as I hate doing big jobs more than once unless I wanted to do it again (e.g. new clutch, etc)
Old May 2, 2017 | 03:32 PM
user 72239's Avatar
Personally I'd only change the timing chain tensioner at 108k.
Old May 2, 2017 | 07:42 PM
LTBALTBMX's Avatar
I ordered the Cloyes kit from Rockauto. The parts all have the same tooling / casting marks so I believe Cloyes is the oem supplier to GM.
The key items to change are the plastic guides, chain, and tensioner. VVT phasers and drive sprocket are probably fine.
Old May 2, 2017 | 08:00 PM
Hmm interesting then I might have to pull the trigger for a set and order a the stg 1 cams
Old May 2, 2017 | 09:54 PM
63 Nova SS's Avatar
Do it!
Old May 2, 2017 | 11:17 PM
T-Man's Avatar
100% agree
Do it once, do it right. Especially with added stress of moving more air/making more power.
Old May 3, 2017 | 09:34 AM
Kolt's Avatar
Chains and guides on these engines have a life expectancy of 150k or so. If your in there it would be a good idea to go ahead and spend the money now and change everything out.
Old May 3, 2017 | 04:01 PM
Devin86's Avatar
I agree just do the tensioner! My 2010 has 133k on these days I did the tensioner at 100k. The chain and all the guides looked fine. My cars been pushing 22+psi since 70k and I'm also throwing on a 71 soon since the weather is steadilybetter here in Cali! Will see what that little engine does lmao worst case i get a new ldk which is no big my little lnf has held in way longer then I would have thought!
Old May 3, 2017 | 07:02 PM
LTBALTBMX's Avatar
The chain stretches. You would not know unless you compared a new chain with the old side-by-side.
I took my chain out at 100k and it was 1 link longer than the new chain.
Just get the Cloyes kit and replace everything it comes with to save yourself the headache.
Old May 4, 2017 | 10:51 AM
colodude18's Avatar
I replaced everything when they installed my built head last year. I figured while everything's apart, might as well. I was only at ~47K but some of those miles were pretty hefty. The way I drive my car it sure wouldn't last 150K lol.
BTW I still have my "old" timing set for sale if anyone's interested!
I'l even separate the timing set from the head. Make me an offer
https://www.cobaltss.net/forums/part...2/#post7629703
Old May 4, 2017 | 10:16 PM
LTBALTBMX's Avatar
Stop trying to pawn your junk off on people. That timing chain set belongs in the trash.
Old May 4, 2017 | 11:45 PM
colodude18's Avatar
Who the f*ck are you?
There is absolutely nothing wrong with that timing set. Or any of the other parts in that thread, for that matter. The numbers in my signature were made with all those parts. I only replaced the timing set as a precaution since everything was apart anyway. Move along if you're not interested.
Old May 5, 2017 | 06:01 AM
Canadia's Avatar
Don't talk to Adrian like that **********
Old May 5, 2017 | 02:52 PM
To me a see that timing chain kit from colodude as an alternative for someone that doesn't have alot funds to purchase new
