2 Step Box for ss tc?
Old Jan 30, 2012 | 03:21 PM
mattdracing's Avatar
Hey guys, this is completely a curious question so please nobody jump all over me. i have a bolted and tuned ss tc. now since with the trifecta tune i have adjustable launch control and all that, is there a possible way to ditch that and do a real 2 step instead on our cars?
Again, i was just curious about this so i appreciate the help!
Old Jan 30, 2012 | 04:06 PM
damastah's Avatar
n2mb wot box...
but i would not recomend it on the stock turbo setup
if you launch your car any more than 5psi, you will most likely be spinning wheels unless you got some real sticky tires
Old Jan 30, 2012 | 05:36 PM
RYRO14's Avatar
I might buy one just for the sound. Nothing better than seeing the expressions of scared people haha
Old Jan 30, 2012 | 06:11 PM
paintballerr78's Avatar
i just bought one cant wait to hook it up to my new setup
Old Jan 30, 2012 | 07:38 PM
Originally Posted by damastah
n2mb wot box...
ohh i gotcha yea i looked that one up a lil while ago. if i ever do it it will only be for the sound every once in a while haha. my trifecta launch control is set at like 60% so if i had a wot/2 step box would i still be able to use the trifecta launch control also? and would the wot shifts work with that box? im a bit confused on how the two will coordinate. sorry for all the questions haha
Old Jan 31, 2012 | 01:19 AM
damastah's Avatar
hhaha. its all good bro. i am a lil unsure about it myself. our cars come with a factory WOT BOX. just have to be extremley fast while doing it. i suck at it. everytime i do it, it throws on a flashing CEL. lol
and our launch control wont build boost in neutral. all it does is hold RPMS at 5100 stock. a 2step box would do same thing. only if you can find a way for your car to build boost in nuetral. which is why i say on stock turbo setup is most likely not worth it.
Old Jan 31, 2012 | 02:17 AM
ryansalazan's Avatar
if someone has it please post a vid for the sound! lol and what rpm its set on
Old Jan 31, 2012 | 04:41 AM
Frogstofall's Avatar
This might be bc you are doing it while the engine is still cold. If the coolant temp is anything below 180, don't even bother.
Old Jan 31, 2012 | 08:37 AM
http://www.youtube.com/watch?v=_YEZ3...3&feature=plcp
Old Jan 31, 2012 | 10:32 AM
yea if i ever do it it will strictly be for sound haha. im trifecta tuned like you so i just wasnt sure how that would work since i already have a launch control...and yea the wot shifts are really hard to hit perfect now that im tuned. if it hits the rev limiter in between a shift it just shuts the motor down and pops and cuts out so i immediately lift off the gas. i rarely ever wot shift but sometimes it works and sometimes it doesnt =/
Old Jan 31, 2012 | 05:40 PM
damastah's Avatar
well. the few times ive done it, coolant temp has always been above 180. also it was a 3rd to 4th shift. and my 3rd gear limiter is raised to 7000. and if i had dont a nls it would have been at 6900. so it would hit the limiter no matter how fast i want to do it.
Old Jan 31, 2012 | 07:34 PM
DerekDTP!'s Avatar
the speedo lags too, i was doing that alot too then i figured out i was hitting it way too late causing a misfire(blinking CEL) try it a lil earlier
Old Feb 1, 2012 | 12:16 AM
Nfamous60's Avatar
so the bottom line is thw 2step isnt gud unless you turbo swap? and the wot box is dependent on your driving ability? i have one already but was advise not to put it in because my car has traction control, but the NLS in my car is headache being that i have a aftermarket clutch.
Old Feb 1, 2012 | 06:37 AM
FasterIsBetter's Avatar
Yeah, that vid is cmiller. Pretty sure hes using the stock launch control.
Old Feb 1, 2012 | 10:13 AM
bogalusahondakiller's Avatar
Thats not stock launch control. Our stock launch control is slow it's no where near that fast
Old Feb 1, 2012 | 10:22 AM
I'll have to look again, but I believe you can control the cut and resume in HPT on our cars by rpm for launch control. That would give the same effect. Its not faster, its just theres a difference in rpm between the cut and resume unlike the way launch control is set stock.
Old Feb 1, 2012 | 11:45 AM
It's a wot box he has other videos telling his settings
Old Feb 1, 2012 | 11:57 AM
Gotcha
06MetallicBalt
Jul 20, 2025 08:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
c_m_shooter
Sep 27, 2015 04:40 PM
