2008 SS/TC, p0087
2008 SS/TC, p0087
So i did a search for this and all it brought up was one of two things:
1. It's a fuel pump/regulator
2. Bring it to the dealer.
It popped up around 6500rpms around 25/26psi.
Option 2 isn't going to happen, it's not warrantied as is.
I'm looking for the prices on replacing the stock fuel pump, or possibly upgrading. Anyone have a link or something where it would give me info on location of the pump, price of pump parts, etc etc?
I'm hoping to get back some technical info from some of the great guys on here who bust their own knuckles working on their cars. If you're response is going to be "bring it to the dealer", hit alt-f4 for me please.
Thanks guys!
Thanks guys!
Take it to the dealer
Seriously... this is what it says...
xTooltipElement
Service Information
2008 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 1957290
DTC P0087, P0088, or P0089
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P0087: Fuel Rail Pressure (FRP) Too Low
DTC P0088: Fuel Rail Pressure (FRP) Too High
DTC P0089: Fuel Pressure Regulator Performance
Circuit/System Description
The fuel rail pressure sensor detects fuel pressure within the fuel rail. The engine control module (ECM) provides a 5-volt reference voltage on the 5-volt reference circuit and ground on the low reference circuit. The ECM receives a varying signal voltage on the signal circuit.
High pressure fuel is regulated by the high pressure fuel pump actuator, which is a part of the high pressure fuel pump. The high pressure fuel pump actuator is a solenoid valve. The ECM provides battery voltage on the actuator high control circuit and ground on the actuator low control circuit. Both circuits are controlled through output drivers within the ECM. When deactivated, both drivers are disabled. When activated, the actuator low control circuit driver connects the low control circuit to ground and the actuator high control circuit driver pulse-width modulates (PWM) the high control circuit.
The high pressure mechanical fuel pump is driven by three lobes on the camshaft. The ECM uses the camshaft and crankshaft position sensor inputs to synchronize the high pressure fuel pump actuator with the position of each of these camshaft lobes. The ECM regulates fuel pressure by adjusting the portion of each pump stroke that provides fuel to the rail.
The ECM creates a feedback loop between the pressure sensor and the high pressure fuel pump actuator. If the difference between expected and actual inputs exceeds a calibrated value, or if the amount of correction exceeds a calibrated value, a DTC sets.
Conditions for Running the DTC
DTCs P0090, P0091, P0092, P0191, P0192, P0193 are not set.
The ignition 1 signal parameter is less than 18.1 volts.
The relative injected fuel mass is between 5.016-500 percent.
The deceleration fuel cut-off (DFCO) is inactive.
The engine speed is greater than 25 RPM.
The engine start temperature is greater than -48°C (-54.4°F)
The DTCs run continuously when the above conditions are met for 2 seconds.
Conditions for Setting the DTC
P0087
The actual fuel pressure is 1.5 MPa (218 psi) less than the desired fuel pressure.
P0088
The actual fuel pressure is 2 MPa (290 psi) greater than the desired fuel pressure.
P0089
The fuel pressure adjustment is greater than +2.5 MPa (+363 psi) or less than -2.5 MPa (-363 psi).
The DTCs set when the above conditions are met for 4 seconds.
Action Taken When the DTC Sets
DTCs P0087, P0088, and P0089 are Type A DTCs.
A message center or an indicator displays Reduced Engine Power when DTC P0087 sets.
Conditions for Clearing the DTC
Diagnostic Aids
A skewed fuel rail fuel pressure sensor may set these DTCs.
Faulty fuel injectors may set DTCs P0087 or P0089.
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Component Connector End Views
Description and Operation
Fuel System Description
Electrical Information Reference
Circuit Testing
Connector Repairs
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Scan Tool Reference
Control Module References for scan tool information
Circuit/System Verification
If any other DTCs are set, perform those diagnostics first.
Operate the vehicle within the parameters described in Conditions for Running and Conditions for Setting. The DTC should not set this ignition.
⇒ If the DTC sets this ignition, proceed with Circuit/System Testing.
Important: Circuit/System Verification must be performed first or misdiagnosis may result.
Verify the correct low side fuel system pressure. Refer to Fuel System Diagnosis.
Remove the high pressure fuel pump and visually inspect the lobes on the camshaft for wear.
⇒ If the lobes are normal, replace the high pressure fuel pump.
⇒ If the lobes are worn, replace the camshaft.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Fuel Injection Fuel Rail Fuel Pressure Sensor Replacement
Fuel Pump Module Replacement
Fuel Pump Replacement
Intake Camshaft and Valve Lifter Replacement
Š 2009 General Motors Corporation. All rights reserved.
xTooltipElement
Service Information
DTC Descriptors
P0087
P0088
P0089
Diagnostic Aids
Schematic Reference
Circuit Testing
Connector Repairs
Wiring Repairs
DTC Type Reference
Scan Tool Reference
Repair Instructions
Repair Instructions
Repair Instructions
So basically do you know if you are getting the correct fuel pressure before the high pressure fuel pump? If not then it's the intake pump.
If you have good pressure there, then check the high pressure pump for wear.
Holy two year old thread revive on an even older thread
camaromanss1992
Oct 1, 2015 10:51 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
