265/40/18's
Old Apr 20, 2011 | 08:27 PM
2006RedCobaltSS's Avatar
265/40/18's
Has anyone tried to run them? I remember a Guy a while ago running nt-05 tires in that size but don't remember if they rubbed or not. Got an awesome deal on some Mickey's.
Old Apr 20, 2011 | 08:41 PM
TCslowbaltSS's Avatar
I'm running 245 40 18 nt555s and lowered on ksport springs and after settling I scrape going around turns at speed and turned onto hills
Old Apr 20, 2011 | 08:43 PM
Dart_SI's Avatar
One guy ran some 285's for his track set up.
I'm running your exact same setup with no problems at all
Old Apr 20, 2011 | 08:46 PM
CordiaDOHC's Avatar
Ive seen some 255s posted on here.
Heres a link to a guy that ran 255s on 17's....
https://www.cobaltss.net/forums/auto...rrived-242175/
But if you want a good answer from one of the best people when it comes to deltas hit up the op in this thead. This guy he should have a good answer for you. He also makes some very nice parts for these cars! .
https://www.cobaltss.net/forums/whee...-9-5-a-214630/
Old Apr 20, 2011 | 08:52 PM
whyyoumadson?'s Avatar
powells car is 5x114.3
Old Apr 20, 2011 | 08:55 PM
CordiaDOHC's Avatar
Yes I know. PF01s arent available in a 9.5 on a 110 bolt pattern. However powell will know best just from his experience.
Old Apr 20, 2011 | 09:13 PM
245/40/18 will rub on with certain tires on a 18x9. all depends on the sidewall design and your ride height. stock ride height or a slight drop will be fine but too low you will need body work to tuck them enough. 18x9.5 is big and will require some body work. the redlines are a lot more forgiving then the cobalts and johns fenders and quarters are rolled.
Old Apr 20, 2011 | 09:16 PM
CordiaDOHC's Avatar
True. I have 235/40/18 kumhos and they seem to run a bit on the small side.
Im not sure of a cobalt running an 18x9.5 currently.
think most are on 18x8's. But john will be able to advise him.
Old Apr 20, 2011 | 09:19 PM
john and i have dicussed this indept.....unless you do body work your not getting 9.5" rim in there period. a 18x9" rim witha 35mm offset is doable with rolled lips and 245s which will have a very slight stretch
when i had h&r springs on there(looks only) i rubbed with both the continentals and the re-11s. with the stance coilovers i still rubbed but i was at almost the same ride height. both 225/40/18.
Old Apr 20, 2011 | 09:21 PM
i mean op... are you looking just to drag race these and have a seperate set of tires for the streets?
Old Apr 20, 2011 | 09:22 PM
CordiaDOHC's Avatar
Yeah and I wouldnt go over a 235 on SS/TC wheels either. I know plenty of people have gone 245 though.
Old Apr 20, 2011 | 09:23 PM
CordiaDOHC's Avatar
Probably drag racing is my bet but will probably want to run them on the street
Old Apr 20, 2011 | 09:24 PM
they can be ran at stock ride height. might want to put some drag bags out back and make them real stiff to avoid rubbing.
Old Apr 20, 2011 | 09:25 PM
CordiaDOHC's Avatar
he's on ksport springs and sits fairly low.
Old Apr 20, 2011 | 09:33 PM
more then likely going to rub. especially if hes on a 18x8 he will have a more protruded sidewall as 245s are ment for a larger width rim.
Old Apr 20, 2011 | 09:44 PM
Glowbalt's Avatar
Good question. I'm running 18x7.5's on 225/40/18 and about to trade for some 245/40/18..Will they rub?
Old Apr 20, 2011 | 09:45 PM
it really depends....the sidewall comes into play some dont some do...ones i know do are the star specs and re11s for sure. what are you dropped on? i wouldnt put 245s on a 7.5" rim though.
Old Apr 20, 2011 | 09:50 PM
Glowbalt's Avatar
Dropped on H&R's..I've had 245's before but they were on 16" rims..
Old Apr 20, 2011 | 09:51 PM
i rubbed with 225 40 18s on h&r springs on a 18x8s....pretty sure you will rub
Old Apr 20, 2011 | 10:01 PM
drewbroo's Avatar
I have 245/40/18 NT-05's on my sedan.... no issues at all other than actually having traction.
Old Apr 20, 2011 | 10:04 PM
ssblackstealth's Avatar
corn gas ftw....
will not work on the stock 8in wide rim.....
for a drag set up 265 is as high as id go but you wont be able to turn for crap!!
street and daily drivability id stick with no bigger than a 235/40
exactly different sidewalls...... i know if i had 245 re11s i would rub
Old Apr 21, 2011 | 12:06 AM
CordiaDOHC's Avatar
SS/TC wheels arent 8 inches they are 7.5 so 245 is a bit too wide for them.
Yeah the tires will fit its just a bit too wide on the wheel to be optimal but it works and looks good.
{TEAM ADRENALINE}
Wheels and Tires
Sep 20, 2010 10:47 PM
